Pesky Rusty Bolts
this thread has 20 replies and has been viewed 821 times
Old 06-06-2019, 11:51:53 AM
Power Power is offline
Default Re: Pesky Rusty Bolts
Originally Posted by Railroads View Post
The torch idea is tempting. But, I don't want to raise the temps of the stator to anything above 145 degrees F. Doing so risks the slot insulators and the wires. Some of these sets are wound with CCA wire. Not the most durable stuff.
I wrecked a 1/2hp DC motor heating the rusty rotor shaft nut. I ended up wrecking the commutator. The heat went up the rotor shaft from the nut being heated and ruined the glue holding the segments in place. That one failed spectacularly.
I might try carefully using a large punch or rod, and giving the long bolt a couple raps. I don't want to crack the plastic end bell either rapping on the bolt.
Robert
If enough room, I tightly wrap a large soaking wet rag around what I want to protect and beyond. I have a spray bottle of water right there, so I am not tempted to do just a bit more as rag dries.
Rusty Lister SR1 onstottc Vintage Diesel and Oil Engines 19 03-05-2015 02:42:44 AM
Rusty AENLD before and after... YellowLister Wisconsin Engines 5 02-22-2013 10:36:18 PM
Rusty Engines Rusty Engines Smokstak Down Under 8 08-09-2009 04:26:31 AM
Rusty Tanks Horse Power at 511 Small Air Cooled Gasoline Engines 12 10-08-2007 10:24:25 PM
Loose rusty bolts vern0n Antique Gas Engine Discussion 6 08-20-2005 10:05:33 PM
