Mecc Alte spa ECO 28-1L/4 15KW output only 55 volts max
this thread has 25 replies and has been viewed 939 times
Old 04-01-2019, 02:57:04 PM
Yotabota Yotabota is offline
Default Re: Mecc Alte spa ECO 28-1L/4 15KW output only 55 volts max
I could take them the whole thing engine and all, I have a tractor with forks. I installed it where it is, just never been on the inside of generator. It has hooks on it the gen part. Has bolts around the engine on outside and would guess remove screens on sides to remove on engine flywheel. I figured why can't you go at it from the other end? I removed the 4 rods but looks like rear is pressed on with the the bearing and metal looks fragile like "pot metal". I see where u at. I'm trying to have a Ships Engineer 23 years exp come look at it. I know those Ca prices are HIGH but what is a ball park figure.
Old 04-01-2019, 04:11:15 PM
I am reasonably sure that the regulator on hand can be wired to use the output windings as both power and sensing. See this page from the manual I linked earlier.
Old 04-01-2019, 04:32:12 PM
I have that paper comes with regulator. So you saying rewire it like this: #1- Blue stays,#2 blank stays, #3 yellow stays, red remove from #3A and install on #4A, green stays on #4, other red #5, Jumper that was on #6 & 5A moves to #3A and #4. Black stays on #5C. Ones not listed now will be blank/no connections?
Do I have this correct? I will install original AVR in case something happens if good I have 2 to return. Will all work well in this situation? Can I still run AC with nothing else on it etc gets hot here ya know.
Old 04-01-2019, 04:59:25 PM
Originally Posted by Yotabota View Post
I have that paper comes with regulator. So you saying rewire it like this....
With all due respect, I'm not comfortable with providing detailed wiring instructions remotely. This is the "procedure that would take me 10 minutes...complicated for remote instruction" thing I mentioned earlier. My thinking (with no warranty expressed or implied) is only 4 wires from your generator to the regulator - 2 (blue-yellow) for the field and 2 (green-black) for power/sensing. The placement of those leads and the needed jumpers between other AVR terminals are explained on the linked page.
...Will all work well in this situation? Can I still run AC with nothing else on it etc...
I do not know how well it will or won't work, and make no warranty expressed or implied.
Old 04-01-2019, 06:10:34 PM
Thumbs up Re: Mecc Alte spa ECO 28-1L/4 15KW output only 55 volts max
Mr. Wayne440, just a quick note to you. I have power PTL and thank you very much,and to Mr. Vogt. Oh and PTL I am fine and it's fine. If make you feel any better I can do electrical no problems, I wired my home and use to do ALL the maintenance for 23 Bank Branches. I just like to concur with what I am doing. The good news I have a generator that works again. I got to run for now will talk to you later again I thank you both very much I owe you a hamburger at least.
Old 04-01-2019, 06:17:45 PM
Glad you have it working and thanks for letting us know the outcome. Many times people just disappear after they get things going (or not) and we are left to guess what might have happened.
Mecc Alte ECP32 gen-end to a Kraus Naimer C80-6 Voltage Selector generatorguy Generators & Electric Motors General Discussion 0 02-04-2019 05:48:21 PM
Mecc Alte Generator wiring to voltage regulator eng.moh.4u Generators & Electric Motors General Discussion 1 02-20-2017 03:28:10 PM
Mecc Alte synchronous alternator info Dr.Fiero Generators & Electric Motors General Discussion 9 12-02-2014 06:33:17 AM
Mecc Alte, Help with twin bearing setup r77 Generators & Electric Motors General Discussion 6 02-18-2013 05:58:53 PM
MECC Alte ECP28-S/4 alternator connections stakstak Generators & Electric Motors General Discussion 31 09-07-2012 09:32:35 AM
