Can The Speed be Increased on a Low Speed GenSet Engine?
this thread has 12 replies and has been viewed 434 times
Old 05-31-2019, 11:30:21 AM
ssmithfam ssmithfam is offline
Default Can The Speed be Increased on a Low Speed GenSet Engine?
Hi All
I'm a longtime member and periodic lurker, but haven't posted much.
I refurbish vintage garden tractors as a hobby. As such, I sometimes repower the machines with an updated engine.
I have a Bolens HT23 with a front end loader and a Kohler K582 with a hole in the block.
I want to repower it with a diesel engine, and have found a Lombardini 9LD561-2L in a light tower genset. The Lomba is a 2 cylinder inline air-cooled diesel. It has a Bosch style injection pump that is timed by shims between the inj pump and cam, and fuel output changed by shims in the individual pumps.
The problem is the Bolens has a hydrostatic transmission and needs to run in the 3,000-3,600 rpm range while the Lombardini runs at 1,500 rpm. The same model Lomba engine is also available in a 3,600 rpm version.
My question:
What would be involved in getting the Lomba to run at higher rpms--at least 3,000 rpm?
Can it be adjusted by adding or removing shims on the injector pumps, or do I need to buy a new pump?
Thanks,
Smitty
Old 05-31-2019, 02:36:51 PM
AngrySailor AngrySailor is offline
Default Re: Can The Speed be Increased on a Low Speed GenSet Engine?
I don’t think it will like running at double rated speed. Aside from damage it will probably be way past it’s torque peak. You would be better off to use a step up gearing arrangement.
Old 05-31-2019, 11:25:02 PM
Thanks for the input. Lombardini also makes an LD561-2 which runs at 3,600 rpm, so I'm hoping that increasing the speed is a simple adjustment of some type, or minimal parts replacement.
Smitty
Old 05-31-2019, 11:31:40 PM
Email NOT Working
I would guess the opposite, that it mostly could run at 3000+ RPM.
But if it was built as a 1500 RPM generator engine then the only way to know for sure would be to get the parts list of this existing engine and the parts list of the high speed engine and compare to make sure they are right.
Rods, pistons, camshaft, injectors, pumps, timing would be the things to look closest at.
Old 06-01-2019, 02:43:12 AM
Don't forget that those aluminum diesels are quite noisy. I wouldn't want to be sitting with it hammering away 3 feet in front of me for a few hours.
If it was me, I'd find another 582.
Old 06-01-2019, 02:56:51 AM
Speed change would not involve the shims, which set timing. On single cylinder Lombardinis the speed is set on govenor assembly. Lombardini is now owned by Kohler. I'd try running your model number on the Kohler site to see if they offer an operators or service manual pdf file, which should cover speed adjustment.
Doc
" When in doubt, tell the truth" - Mark Twain
The Following 2 Users Say Thank You to Thaumaturge For This Post:
Old 06-01-2019, 08:45:18 AM
30 seconds on Google yielded this-
https://struckcorp.com/downloads/mh6...p%20Manual.pdf
Old 06-01-2019, 03:10:48 PM
Sadly that manual specifically state for 9LD561-2L an RPM of 2000. So no go on 3000 RPM, at least by direct drive. Is there room to provide for 0.66:1 (2:3) belt ratio?
Doc
Old 06-02-2019, 12:00:07 AM
I stand corrected. The 9LD561-2 is 3,000 rpm as you stated.
I got a workshop manual last week, and a parts manual. The only differences I've found noted, aside from the rpm, are that the LD561-2 timing is 24 - 26 degrees, while the LD561-2L timing is 22-24 degrees.
I haven't found any parts listed that are specific to the 9LD561-2L, though one would assume that at least the injection pump, and possibly the injectors, are different.
Per the workshop manual, timing is changed by adding or removing shims from the area where the injection pump mates to the engine block--thus increasing or decreasing the distance from the plunger to the cam.
There also is a mechanical governor, which controls speed through a flyweight that is opposed by springs. I suspect that replacing the springs with lighter springs would allow higher speeds.
At any rate, thank you for the response.
Smitty
---------- Post added at 09:55:24 PM ---------- Previous post was at 09:51:10 PM ----------
Doc
Thanks. I was able to download a service manual and parts manual last week. I haven't been able to find anything that shows different part numbers between the "normal" and the "slow" version of the 9LD561-2.
Smitty
---------- Post added at 09:58:32 PM ---------- Previous post was at 09:55:24 PM ----------
Doc
Thanks for the suggestion. Unfortunately there isn't room for speed reduction.
I'm looking to use the engine to repower a vintage garden tractor. I have a couple candidates, a Bolens HT23, and a MTD995. Both are shaft drive to the hydrostatic rear end and there isn't room to squeeze in a gear reduction gear box of any size, not to mentoin one capable of handling 18-20 hp.
Regards,
Smitty
---------- Post added at 10:00:07 PM ---------- Previous post was at 09:58:32 PM ----------
Originally Posted by Wayne 440 View Post
Thanks. I failed to mention that I already have a service manual and parts manual for the engine.
Smitty
Old 06-02-2019, 01:27:20 AM
Email NOT Working
Yes, you are right that all the governor parts would have to be checked for commonality.
Also the crankshaft or fan drive pulley might be different so as not to overspeed the fan, and so the water pump is going the right speed.
Old 06-02-2019, 01:10:53 PM
Vanman Vanman is offline
Interesting. I'm surprised the timing difference isn't greater. But then again, they may want to make it still tolerate being overloaded at low speed- "lugged".
Old 06-02-2019, 02:03:42 PM
I don't think they would have made a special engine for lower speed, they just ran it slower, timing may have been changed for maximum efficiency at lower speed. I would run it, should be a throttle lever with high and low speed stops.
Old 06-02-2019, 11:50:31 PM
That's a good point I hadn't thought of.
BTW, how do you do a "Thanks" on other people's posts? I haven't found a button to click?
Smitty
---------- Post added at 09:50:31 PM ---------- Previous post was at 09:48:31 PM ----------
Yes, there is. I haven't seen the actual engine, it's just listed for sale in a local online classifieds, but my Ruggerini uses a couple screws with locking nuts to adjust speed. Ditto with my (now stolen) Kohler.
Smitty
Low speed or "Regular Speed" grinder for sharpening? ChrisinEstes Machine Shop and Tool Talk 11 02-27-2017 06:18:41 PM
Engine Speed thiggy Maytag Engine Collectibles 1 09-18-2015 03:47:10 PM
Onan DJE genset manual speed/voltage regulation? Vicentropy Onan Generators 7 10-16-2014 09:35:22 PM
Question about Generator Speed and Motor Speed iceman Generators & Electric Motors General Discussion 7 06-12-2010 02:08:08 PM
Engine Speed (RPM) shoptek Antique Gas Engine Discussion 7 03-15-2009 06:28:26 AM
