Oil Field Engines
Fairbanks Morse 118 or 204 questions
this thread has 26 replies and has been viewed 8385 times
Old 10-24-2009, 05:42:37 PM
DirtbikePilot DirtbikePilot is offline
Default Re: Fairbanks Morse 118 or 204 questions
I have to respectfully disagree with Jim. I have a 15 hp FM Z engine on a heavy duty cart with heavy duty casters that have steel wheels. It weighs about 2500 pounds all together and it is pretty easy to push around on level cement. Once I get the heavy flywheels on it, it will weigh over 3000.
Old 10-25-2009, 01:43:59 PM
Reed Engine's Avatar
The first thought that comes to my mind is Dirtbikepilot may be a tad younger than Jim Gorter.
Old 10-25-2009, 02:51:23 PM
Alan D. Alan D. is offline
Do any of you have a spare 118 or 208 FM carb spare and for sale? I will be needing one in the very near future.
My 2 cents on the weight of 118 or 208's. I will be purchasing on of these, but don't know yet as I have not decided which one will suit my needs and interests better. I do plan to build a dedicated rubber tired trailer, not to big but adequate to pull the engine to where I need to use it. I can then back it into my farm building when not in use and keep it out of the weather. I would then not be fighting continually with the physical weight. I just need to decide between the 6 hp 800 lb. 118 or 1200 lb 12 hp 208. I do assume the weights, that have been shared with me, include the weight of the stock flywheels?
Thanks for your taking time to respond and give me decent ideas to consider.
Regards, Alan D.
Old 10-26-2009, 04:35:05 PM
Jim Gorter Jim Gorter is offline
Ed, You may be correct in your assumption, I dont know the age of Dirtbike pilot, but it sounds like he shows his engines in a different venue than myself. My shows are in wet grassy parks. Have never shown engines on level concrete except in the shop. All my bigger engines, 6 hp and up are on skids and I load and unload with a forklift. Much easier to push pedals than a 2500 lb hernia waiting to happen. We "old guys" need to be a bit more careful in our advanced years. Jim.
Old 10-28-2009, 08:25:12 PM
larrysiebert larrysiebert is offline
Alan, I have a 208 mounted on a scrap rear axle from an anhydrous wagon. It rides and pulls great. Pretty much the setup you were describing. Good luck with your project.
Larry
Old 09-18-2010, 10:31:18 AM
David Doran David Doran is offline
I have a Fairbanks Morse ZC 118 with serial No. ZC091A6&B3 and it has a G above that seris of numbers. Located on top of unit. Serial numbers are hard to read but this is what I could make out.n Anyone have any ideas on this one?
Thanks!
Old 09-18-2010, 12:16:47 PM
Here is my Fairbanks Morse ZC 118. As far as I can tell I am missing the magneto, Carb system & fan assembly. The mag gear has been open to the elements for one only knows. Hopefully these pics upload. My question is where to begin on this thing?
Name:	SEPT. 2010 081.JPG
Name:	SEPT. 2010 077.JPG
Name:	SEPT. 2010 082.JPG
Name:	SEPT. 2010 079.JPG
The Following User Says Thank You to David Doran For This Post:
Old 09-19-2010, 12:13:17 AM
Ray Cardoza's Avatar
http://www.enginads.com/classifieds/ post an ad here looking for the parts you need. most guys should have at least something that you are looking for.
and heres a pdf book for a break down on parts and how to re time the engine and mag
http://www.arrowengine.com/media/fairbanksPartsBook.pdf
good luck
The Following User Says Thank You to Ray Cardoza For This Post:
Old 09-19-2010, 09:05:42 PM
Walt Roys Walt Roys is offline
In Memory OF
Alan,
I just did a 118 FBM last winter and recieved great help and advice from this site. I showed it at a local show and at the county fair. It starts easy and is a great runner.
I had a heavy duty cart that I put under it and it moved easy enough even on the grass. Doug Waggoner secured a parts book for me and I have a friend in a town which handles these parts so I was able to get parts I needed in a timely manner. Ed Reed was also a big help in rounding up parts.
Send me a personal message with an e-mail address and I'll send some pics of repair in process. I have not mastered putting pics on this site, but can do the e-mail.
Let me know if I can help.
Walt
The Following User Says Thank You to Walt Roys For This Post:
Old 09-21-2010, 09:59:18 AM
Hey Walt your Private Message is off but I sent you an e-mail with my address, will be looking forward to the pics of your rebuild. Thanks for yours & Rays input as it will assist me with a starting point!
David
Fairbanks Morse ZC-503 and ZC-346 Questions Christian Berlin Antique Gas Engine Discussion 14 10-26-2009 11:58:50 PM
Fairbanks Morse 3 hp Z questions? Zira Antique Gas Engine Discussion 21 02-17-2009 10:46:24 PM
Fairbanks Morse 3 hp Z Questions Doug Kimball Antique Gas Engine Discussion 1 01-22-2009 10:41:33 AM
Questions on Fairbanks Morse Shine Stringer Antique Gas Engine Discussion 10 10-03-2007 02:38:16 AM
Fairbanks Morse 3HP ZC Questions Alan James Antique Gas Engine Discussion 0 05-29-2007 03:55:28 AM
