Gas Traction Big 4 from Blomgren Estate
this thread has 1223 replies and has been viewed 399442 times
Old 05-22-2012, 05:06:50 PM
Alan Svanes Alan Svanes is offline
Default Re: Gas Traction Big 4 from Blomgren Estate
I though about a shaper when you had to cut a tapered internal Keyway. They do take a lot of space but there are somethings they are very useful for. Alan
The Following 2 Users Say Thank You to Alan Svanes For This Post:
Old 05-24-2012, 12:12:26 PM
Allan Severson Allan Severson is offline
We are machining the differential turnbuckle bolts for the Big 4 tractor. They will be used to get the correct gear mesh between the rear axle and differential. The other end of the turnbuckle will be an eye bolt which hasn't been made yet.
Old 05-25-2012, 12:09:13 PM
Today we reached a milestone, which is passing 100,000 views. Thanks to everybody for following the progress of our Big 4 tractor.
Harriet and Allan Severson
Old 05-26-2012, 07:07:46 AM
34 40 34 40 is offline
All the Thanks to you folks! You make it possible to learn and enjoy at the same time! So, thanks again Harriet & Allan Severson!
The Following User Says Thank You to 34 40 For This Post:
  #535
Old 05-27-2012, 11:50:05 PM
Norm Johnston Norm Johnston is offline
Allan Do you or maybe someone else know how to establish the production date of Big Four tractors, I am keen to know when mine turns 100 years old as I have a few requests of late to show the tractor at upcoming rallies, and would be keen to celebrate the tractors 100th birthday but would like to be as accurate as possible.
Old 05-29-2012, 01:59:05 AM
The only thing I know is Emerson Brantingham bought Gas Traction out in what I believe to have been September of 1912. Mine is a Gas Traction, and is serial number 1131 and the tractor in Monticello, Utah, which is an Emerson Brantingham, is serial number 1189 according to David Parfitt's registry. I am believing mine to be a 1912.
The Following User Says Thank You to Allan Severson For This Post:
  #537
Old 05-29-2012, 02:15:49 AM
Talking Re: Gas Traction Big 4 from Blomgren Estate
ALLAN! How are you going to get anything done if you're up all night?.......
(Like me....... )
  #538
Old 05-29-2012, 02:33:00 AM
Isn't that how you get things done???? Actually, we are visiting my wife's sister in Anchorage, Alaska.
  #539
Old 06-04-2012, 10:09:50 AM
We are bending turnbuckle ends for the steering and differential of the Big 4 tractor. We are using a Hossfeld no. 2 bender. The rods were pre-heated before bending to help minimize stress cracks that would have been there if they were bent cold. We are using 3/4 inch rod and bending around a 5/8 inch pin.
Old 06-06-2012, 09:10:50 AM
We have finished the steering turnbuckles and the differential adjustment rods. In the first attached picture we are showing a picture of the bending process for offsetting the eyelet of the turnbuckle end. The next picture shows the assemblies, and the final picture shows the finished steering turnbuckles with the previously made shock absorbing springs.
ID:	137058   Click image for larger version
ID:	137059   Click image for larger version
Morris Blomgren 3 day auction QuickJ Live Auctions of Engines, Tractors and Old Iron 50 01-22-2011 08:07:53 PM
Kreiner estate Plymouth NY SteveK Live Auctions of Engines, Tractors and Old Iron 2 10-01-2010 12:35:44 AM
Blomgren Auction-Steam & Antique Tractors Jim Friedrich Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 09-07-2010 10:52:55 AM
Estate sale in Montrose, Mi Craig A Live Auctions of Engines, Tractors and Old Iron 0 02-14-2009 10:43:11 PM
Wilson Estate Auction John Zalabak Antique Engine Archives 2 11-10-2003 08:19:05 PM
