Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Honda, Yamaha, Kawasaki, Isuszu Generators
EB6500 Honda Generator
this thread has 8 replies and has been viewed 724 times
Old 05-20-2019, 02:22:11 PM
ziggyco ziggyco is offline
Default EB6500 Honda Generator
The fuel solenoid will not work. I've replaced it. I have power to the starter, but when I hit the key, the solenoid will not open. I've tested the new solenoid and it works. Any Ideas? Do I have a bad starter switch?
Old 05-21-2019, 06:14:24 PM
Default Re: EB6500 Honda Generator
Have you checked the wiring between the key switch and solenoid?
Old 05-22-2019, 09:21:16 AM
Yes. All looks good, no bare wires. Starter switch has multiple wires going to and out. New switch is around $90.00.
Old 05-22-2019, 03:49:06 PM
radiodoc radiodoc is offline
I would test for voltage at the solenoid with a test light or voltohm meter. If no voltage, then check where the lead to the solenoid comes out of the switch.
Old 05-23-2019, 10:47:33 AM
Will Do. Thanks
Old 05-29-2019, 04:31:32 PM
Ck'd lead's from switch and no juice. So I'm guessing bad switch. Any other ideas besides the switch? Thanks Ziggy
Old 05-30-2019, 08:16:26 AM
StringJ StringJ is offline
I would try something like this before spending $90.00 for a switch.
https://www.amazon.com/CRC-05103-Ele...omotive&sr=1-1
Jerry
Old 05-30-2019, 11:22:49 AM
Ziggyco the CRC electronic cleaner Stringj mentioned would be worth a try. It can be had at Walmart or most auto parts stores.
Old 05-30-2019, 11:35:31 AM
Just happen to have some. Will give it try. Thanks
EB6500 won't shut down maxepr Honda, Yamaha, Kawasaki, Isuszu Generators 2 11-21-2016 02:31:00 PM
Honda EB6500 runing but No Power n4v4jo Honda, Yamaha, Kawasaki, Isuszu Generators 13 10-21-2016 08:34:45 AM
free honda eb6500 EnginePat Honda, Yamaha, Kawasaki, Isuszu Generators 4 10-11-2016 10:30:35 AM
Honda Generator LiverpoolDave Small Air Cooled Gasoline Engines 0 03-01-2014 05:09:47 PM
xfer switch with eb6500 powerking Honda, Yamaha, Kawasaki, Isuszu Generators 10 08-10-2013 02:58:38 PM
