Dyna 12 kW generator: Exciter coil
this thread has 2 replies and has been viewed 2473 times
Old 02-06-2012, 03:08:02 PM
Brian W Brian W is offline
Default Dyna 12 kW generator: Exciter coil
I have an old 12 kW Dyna Generator that I got in pieces. I am pretty sure that its from the 1970 based on the Lister/Monarch engine it was paired with. One problem is that the Exciter coil has had a screwdriver shoved thru it. I think the last guy was trying to pry apart the metal discs that it's sandwiched between but the screwdriver slipped off and went thru the winding.
A local shop quoted $600 (US) to rewind. I was shocked that it was that much since its a stationary coil. The Winco/Dyna website doesn't show anything for generators as old as mine. Not that I saw, anyway. Does anyone know where to look for replacement parts? I am not oppsed to shipping, but I live in Oregon, USA.
Dyna generator model number: CSA12PDM4G - 3/B (s/n: 39080-M82)
Lister/Monarch engine model number: CSR3Z01994 MO1
thanks, Brian
Old 02-06-2012, 08:40:11 PM
nehog nehog is offline
Default Re: Dyna 12 kW generator: Exciter coil
Pictures are important as they can tell more than words do... Both the full unit, and the coil if possible.
Old 02-07-2012, 12:13:25 AM
coyote62ny coyote62ny is offline
pics might help as someone may have the part you are looking for but may not know what it fits
Lister ST2 with Dyna 8KW Generator advice! mreimers Vintage Diesel and Oil Engines 7 07-07-2013 02:33:23 AM
Onan MDJF exciter coil wanted 15KW marine unit BigBlockChev Onan Generators 4 05-18-2013 08:04:40 PM
Dyna generator? Warren914 Generac Generators (SEARS, etc.) 13 02-13-2011 07:04:01 PM
hobart exciter generator Paul123456 Welding Shop 0 11-15-2005 09:07:22 PM
old generator 660 amps,exciter,early 1930s Tim Beavers Generators & Electric Motors General Discussion 2 03-23-2005 07:47:01 PM
