Engine Speed
this thread has 1 replies and has been viewed 1150 times
Old 09-15-2015, 02:36:32 PM
thiggy thiggy is offline
Default Engine Speed
What speed should I expect from my 72? The slowest speed at which it runs smoothly is about 1400 RPM. Is this usual? Likewise, I cranked up one of my 92s after cleaning up the fuel pick-up, which did not want to run at a show last week. It was turning 900 RPM. Is that overly fast for one of those engines?
Old 09-18-2015, 03:47:10 PM
Exclamation Re: Engine Speed
The 92 runs at about 1150, the 72 twin about 1200. The 72 speed is an average. If you load it to fire at every TDC, it will hold roughly 1050. The 92 develops about 3/4 HP, the 72 in the area of 1/2 to 5/8ths. The 72, being a throttled smaller bore engine has to spin a little faster to make the torque it needs to compete with the 92. Even though the 72 is throttled, it will get better 'milage' on a gallon of gas, due to the smaller bores
How do you set engine speed? bjaspud Maytag Engine Collectibles 3 12-20-2010 12:38:00 PM
Question about Generator Speed and Motor Speed iceman Generators & Electric Motors General Discussion 7 06-12-2010 02:08:08 PM
Engine Speed (RPM) shoptek Antique Gas Engine Discussion 7 03-15-2009 06:28:26 AM
Low engine speed Doug Edwards Antique Engine Archives 12 09-18-2002 08:28:13 PM
Engine Speed Jim Tremble Antique Engine Archives 0 09-18-2002 04:32:52 AM
