Fairbanks Morse 1920 Z questions 3hp
this thread has 4 replies and has been viewed 601 times
Old 04-11-2017, 03:51:56 PM
Mlera Mlera is offline
Default Fairbanks Morse 1920 Z questions 3hp
Hi all
I have a new ( to me) 1920 Z 450000 era with a AB33 mag 3 hp.spoked flywheel
I pulled the head and the piston at TDC is about 2 1/2" from the top of the cylinder is this correct on these motors? Is there another designation (sub model) for these motors ( I see ZC, ZD, ZH) the tag only has "Z" just digging into this one.
Things to do
Rebuild the mag
Machine governor
Valves, guides, and seats
Rod bearing
Ex rod
Throttle rod
This is such a fun hobby
Thanks in advance
Mike
Old 04-11-2017, 04:00:48 PM
Email NOT Working
Default Re: Fairbanks Morse 1920 Z questions 3hp
I can't answer most of your questions and I'm not intimately familiar with the model Z but yes most of these don't squish the fuel charge very much.
A lot of the old engines had igniters on the left side of the cylinder and of course the Piston couldn't go past that point and still expect to fire.
Old 04-11-2017, 05:29:27 PM
Thank you Kevin
Looked at the squish scratched my head thinking is the piston wrong!
That makes sense about the side ignitor
Old 04-11-2017, 07:28:49 PM
AKMark AKMark is offline
ZC is a closed crank, ZD is a small closed crank also called a salt block. Yours is a Z have fun with it.
Old 04-12-2017, 02:08:39 PM
Thank You I will
1920 Fairbanks Morse 3 HP Z Engine Larry A Macon Antique Gas Engine Discussion 9 06-24-2014 01:02:53 PM
Fairbanks Morse 118 or 204 questions Alan D. Oil Field Engines & Related Equipment 26 11-28-2010 12:00:25 PM
Carb position on a 1920 Fairbanks Morse engine Kenny Kline Antique Gas Engine Discussion 2 01-31-2010 02:07:58 PM
1920 Fairbanks Morse Model Z 1-1/2 horse Farmall Freak Unidentified Engines 3 03-05-2009 09:01:21 PM
Fairbanks Morse Z Questions Andrew_S Antique Gas Engine Discussion 4 07-14-2008 08:04:53 AM
