Kohler Generators
CCA Battery size for 3RM21 generator?
this thread has 5 replies and has been viewed 2676 times
Old 09-03-2007, 10:43:22 AM
fordiesel69 fordiesel69 is offline
Default CCA Battery size for 3RM21 generator?
Being I have no manual, I want to use the lightest weight battey needed to crank this over. A car battery works great but I would like to use maybe a motorcycle battery or a lawn tractor battery. I don't have either one, so I don;t want to just buy one and have it not work. Anyone know how much it takes to turn one of these over?
Old 09-08-2007, 01:25:03 PM
Default Re: CCA Battery size for 3RM21 generator?
anybody have an estimate?
Old 09-08-2007, 06:55:12 PM
Fred M. Fred M. is offline
Fordeisel69-
I have a portable "Jump-start" battery purchased at Walmart. It has a 22 Amp Hour Gel Cell battery, and the box it came in claims it is capable of supplying 600 Amperes for the time it takes to jump-start an automobile with a dead battery. While I don't fully believe such a claim, it has worked to start a car with a dead battery on at least a couple of occasions.
This doesn't directly answer your question, but may give you an idea of how a lawn tractor battery might work for your generator. How does the size of the engine compare with a lawn tractor's engine?
Another thing to consider, is how you will keep the battery charged. Does the 3RM21 have a built-in charging system? Might it over-charge a battery that was too small? Does the generator have a battery box or tray? If so, does it look as if it were designed for a particular size battery?
Fred
Old 09-09-2007, 03:14:37 PM
Thanks Fred,
To answer your questions, the engine does indeed resemble a lawn tractor engine, however the size of a starter on a lawn tractor is very small. These generators do not have have a starter, but rather a Field Exciter, which basically uses the generator portion to crank the engine. When using jumper cables and a good car battery, the engine starts off real slow and then speeds up, almost like there is not enough power. It appears this is the way it is designed but I was nervous of buying a battery too small, have it not crank over and not able to return it.
This is a bare standby generator and there is no accessories. No battery and no gas tank.
Old 09-09-2007, 05:11:45 PM
K D Redd K D Redd is offline
If you have an AUTO-ZONE store in you area look at their heavy duty L/G battery. The battry is rated at 425 Cranking Amps.
Kent
Old 09-09-2007, 11:06:22 PM
jpvaughn jpvaughn is offline
Smile Re: CCA Battery size for 3RM21 generator?
I've started mine l600 with a U1 size battery which is ab out the same as a lawn tractor would use I would think.
Jon
Tiny Tim Generator/Battery Charger John Schwiebert Generators & Electric Motors General Discussion 23 05-18-2017 01:21:13 PM
Kohler 3RM21 generators ironpiston Kohler Generators 6 09-25-2014 07:40:07 PM
Battery size Nubian Onan Generators 9 01-14-2008 03:51:53 PM
Need Manual for Kohler 3RM21 Gen. fordiesel69 Kohler Generators 3 09-04-2007 06:46:43 PM
damage to 12 v generator/starter if no battery attached ??? werfymmot Onan Generators 0 04-04-2006 03:47:48 PM
