1921 Pierce-Arrow X5 Two Ton Truck
this thread has 39 replies and has been viewed 4788 times
Old 11-08-2017, 10:30:39 PM
Chris Props Chris Props is offline
Default Re: 1921 Pierce-Arrow X5 Two Ton Truck
Lowering the cab into place. It has new wood, but is going to need quite a bit of work.
The Following 8 Users Say Thank You to Chris Props For This Post:
Old 11-09-2017, 09:37:23 PM
From the underside pictures, it looks like the cylinders are sleeved. Do you plan on replacing the pistons?
How about the tiny cracks in the head, will they be of concern?
A new driveshaft can probably be readily made up by one of the companies that specializes in that field.
That rear end housing is huge!
Old 11-10-2017, 10:14:16 AM
The cylinders are not sleeved. The block and crankcase are two separate pieces, and what you are seeing in that picture is the joint between the two. The original pistons are going to be reused. There are no cracks in the head, just in the valve seats and extending into the cylinder. It is going to be sleeved and have new valve seats installed.
There is a modern spicer flange that will bolt up if I can't find an original driveshaft, but hopefully an original will turn up even if it is not the correct length.
The Following User Says Thank You to Chris Props For This Post:
  #34
Old 11-11-2017, 12:10:39 AM
Oldtech Oldtech is offline
If you go on you-tube Jay Leno has one of his videos on a 1918 Pierce Arrow with the 6 cyl T head engine. Interesting car. Of Course, I'm an old car guy
The Following 2 Users Say Thank You to Oldtech For This Post:
  #35
Old 11-13-2017, 07:47:04 PM
I thought I was going get away with only having to make a few pieces along with some trimmming here and there but it is better off to just start over. The whole thing was about 1/4 in. too narrow and the arch wasn't quite right.
I have some pictures from the early 90's of the truck in pieces. Sometime between then and now the sheet metal was cut to fit that metal grate in the back of the cab. It is supposed to have a small back window. It is just flat metal so it won't be too hard to fix.
ID:	296012   Click image for larger version
ID:	296013   Click image for larger version
The Following 4 Users Say Thank You to Chris Props For This Post:
  #36
Old 11-19-2017, 08:30:05 PM
The inside of the cab sheet metal had not been sandblasted so there was sort of a "shadow" showing through the red paint of where the wood was originally. Working from that and the drawing in the parts book, I was able to come with something I believe is pretty close to original.
ID:	296496   Click image for larger version
The Following 6 Users Say Thank You to Chris Props For This Post:
  #37
Old 11-20-2017, 12:17:58 AM
j dayman j dayman is offline
What kind of rod do you use to weld that brown stuff?
(just kidding - cab parts look really great.) JD
The Following User Says Thank You to j dayman For This Post:
  #38
Old 11-25-2017, 09:32:04 PM
Got that brown stuff welded together.
ID:	296931   Click image for larger version
The Following 9 Users Say Thank You to Chris Props For This Post:
  #39
Old 11-25-2017, 10:37:44 PM
OTTO-Sawyer's Avatar
I'm guessing you used a "Stick-Welder" for that.
  #40
Old 11-26-2017, 12:15:16 AM
OK Chris . You are making that look way too easy. I've rebuilt wood framed cabs. I KNOW what you did.
1930 Pierce Arrow Engine Keith Schumacher Antique Autos and Trucks 12 12-01-2011 09:31:51 PM
Pierce Arrow jack? For a truck? mschreiber Antique Autos and Trucks 8 03-19-2010 04:11:42 PM
Pierce Arrow Wheels Keith Schumacher Antique Autos and Trucks 2 04-10-2009 08:20:18 PM
Pierce Arrow truck parts wanted BlasterMike Antique Autos and Trucks 19 04-08-2009 12:31:00 AM
