Where to get small copper fuel line?
this thread has 24 replies and has been viewed 4110 times
Old 02-13-2012, 12:59:24 PM
M Schwab M Schwab is offline
Default Where to get small copper fuel line?
Hi all!
This model Y was given to me. It runs good as I squirt gas in the carb/mixer. Now I want to rig up a gas tank. Where can I get the small copper fuel line and fittings it requires? I assume it is 1/8" ? Home Depot and Lowes only carry 1/4" and up.
And I understand that originally a check valve was required on the tank end. Would it still be necessary if the tank was mounted approximately carb height?
Name:	Briggs model Y comp.jpg
Old 02-13-2012, 01:10:33 PM
C-Wade7 C-Wade7 is offline
Default Re: Where to get small copper fuel line?
Try Napa it is also used to plumb oil pressure gauges.
Old 02-13-2012, 02:13:25 PM
Jeff Lauber Jeff Lauber is offline
Napa might have it, but most metal oil lines are either 5/32 or 3/16. the plastic ones are 1/8. Another place to look would an HVAC supplier, as a lot of AC equipment uses the smaller copper line in sencors. I beleive also that the tubing on a themo-coupling is 1/8".
Old 02-13-2012, 02:20:23 PM
mschreiber mschreiber is offline
a guy on ebay has 1/8 copper kits, auto meter packaged, like 1/2 napa. auto meter p/n 3224. make sure 1/8 ain't to small.
Old 02-13-2012, 03:16:01 PM
BobRR BobRR is offline
You should be able to get 1/8c. at home depot or any hardware. Look for a ice maker kit for a refrigerator. Bob
Old 02-13-2012, 04:02:23 PM
Exclamation Re: Where to get small copper fuel line?
1/8" copper is not a home depot item. Try Bob's Small Engine for the check and fuel line.
Old 02-13-2012, 04:43:34 PM
Jim Metzger Jim Metzger is offline
Any HVAC distributor or suply house will have that copper size.
It is common in the A/C industry.
Old 02-13-2012, 06:35:53 PM
Heller D. Davis Heller D. Davis is offline
Our Ace Hwd carries it.
Old 02-13-2012, 10:08:10 PM
Tom G Tom G is offline
I used to get mine at NAPA.
Old 02-14-2012, 07:10:16 AM
Dennis Wyatt's Avatar
Dennis Wyatt Dennis Wyatt is offline
Images: 119
Yep, Ace sells it by the foot. That is where I get mine. As for the check valve, they run a lot better with one.
Dennis
http://www.youtube.com/user/djjr4fun#p/u
6hp jd fuel line 6hpMarty Antique Gas Engine Discussion 8 09-05-2010 11:32:37 PM
Filtration: Fuel Strainer? Anyone have a Photo of F/M fuel-line FUEL STRAINER? DerekC Antique Gas Engine Discussion 1 11-17-2007 06:10:01 PM
Need fuel line(s) for DJC tierramaya Onan Generators 3 06-08-2007 04:56:41 PM
Fuel Line Fred Van Hook Antique Engine Archives 1 11-11-2003 10:05:35 PM
Clinton fuel line David Fisher Antique Engine Archives 0 06-30-2001 04:41:18 AM
