Walker-Turner Bandsaw Restoration
this thread has 5 replies and has been viewed 585 times
Old 11-04-2017, 09:03:57 PM
DustyBar DustyBar is offline
Default Walker-Turner Bandsaw Restoration
I have a 1940's Walker-Turner 14" bandsaw I'd like to restore for use. Actually all it really needs is the blade guide ball bearings. The ball bearing I don't know what to do about is a NICE 6386. Its a ball bearing that is oriented as a thrust bearing and about 2" OD x 1/2" thk x 1/2" ID. The outside race is quite thick and the back edge of the saw blade runs against it. At some time it must have stopped turning and now has several deep groves worn into it. I swapped the shields side for side to run the blade on the other side but its very loud and often stops turning. It seems this bearing is no longer available but some have suggested a regular ball bearing with a collar machined, hardened and pressed onto it. If you machine a collar for press fit, then harden it doesn't that change the fit? Does anyone have ideas on how to fix it?
Old 11-05-2017, 12:33:07 AM
PFT's Avatar
PFT PFT is offline
Images: 31
Default Re: Walker-Turner Bandsaw Restoration
Go to sawblade.com and buy some proper guides with the bearing oriented the correct way. Running the blade against the side of the bearing is just wrong, even if most saws do it that way.
PT
The Following User Says Thank You to PFT For This Post:
Old 11-05-2017, 12:53:15 AM
Ozlander Ozlander is offline
Only one s in sawblade.com
The Following 2 Users Say Thank You to Ozlander For This Post:
Old 11-05-2017, 12:00:28 PM
CharlieB CharlieB is offline
Nothing special about those bearings. Any bearing supplier can match the size and type.
Most band saws use a standard thickness outer race, but if you want the thick one like the OEM bearing, specify a "track roller." Here's an SKF catalog description:
http://www.skf.com/us/products/beari...ers/index.html
The Following User Says Thank You to CharlieB For This Post:
Old 11-05-2017, 04:35:13 PM
If I could find a hardened washer about 2" OD, I suppose I could just epoxy glue it to the side of most any bearing. Since I already have a standard bearing of the size I need I may just try looking for a suitable washer. I'm not ready to spring for $200 blade guides for a saw I wont use all that much.
Old 11-05-2017, 04:57:06 PM
dalmatiangirl61 dalmatiangirl61 is online now
Google search for 6386 bearing gets lots of hits, but for a tapered roller bearing. I'd find a bearing with same dimensions and go with it, worst case you make a collar and don't harden it, when the time comes make a new collar.
Walker Turner DP900 Drill Press dalmatiangirl61 Machine Shop and Tool Talk 8 04-18-2017 11:33:14 AM
Bandsaw, very interesting home built bandsaw Leonard Fausset Machine Shop and Tool Talk 1 01-25-2015 10:07:57 PM
Restoration of Walker drone Gene Fisher Antique Gas Engine Discussion 5 12-22-2013 08:57:41 PM
LOOKING FOR JIM WALKER SONNY L Antique Engine Archives 0 04-10-2003 07:00:36 PM
