Sachs Dolmar Ignition Woes
this thread has 59 replies and has been viewed 11664 times
Old 08-24-2017, 05:01:59 AM
Northmen Northmen is offline
Default Re: Sachs Dolmar ignition woes
Thanks for your reaction I hope i can fix it with this information
Old 09-16-2017, 10:32:08 AM
Hey, so I both a dial indicator an a timing light. It was quite hard to get the piston on 2 mm btdc because you can only put the dial indicator in a certain decrease on the piston.
I used the timing light and everything worked, I let it turn by the electric drill.
And I used starting gas and fuel, but nothing again he don't want to work for some reason!
I am 99% sure thats not the ball bearings. And it is so weird that when the saw is on time now and I put fuel down the throat of the carb that it don't start! There is now life at al! What else can it be?
Thanks for the reply!
Old 09-16-2017, 10:33:45 AM
bigGURN bigGURN is offline
Images: 1
Have you checked compression? Or done as Andrew recommend above?
Old 09-17-2017, 09:29:31 AM
No i didnt do that but he don't give any life at all that's what I think is so weird!
Old 09-17-2017, 09:36:05 AM
Images: 1
If compression is inadequate to compre the fuel/air charge, you'll have no life as there is nothing to ignite.
Old 09-18-2017, 09:29:21 AM
Default Re: Sachs Dolmar Ignition Woes
Oke and how can I check the compression? I read somewhere that's if it is good that it is around 100/125 psi? Is that right?
Old 09-18-2017, 10:39:20 AM
Images: 1
Really 125 is minimum for a nice, easy starting and running saw. You'll need a compression tester to check compression.
Old 09-19-2017, 02:46:04 AM
Thanks I will look for that and try it out, keep you updated thanks for helping
Old 11-06-2017, 12:51:48 PM
So I checkt the compression and it is 180psi so that is really good. I was thinking is it possible that the plug, when it is in the cylinder that it don't make earth? So that it then not fires and when it is out and keep it against the outside of the cylinder that it then makes good contact? So no the compression is good what else can it be? Because there is still no live at all!
Old 11-07-2017, 04:00:42 PM
I can buy a ignition module from a dolmar 152 but dus it fit on my 153? Because I still think it's the timing ore something like that.
Military Standard 4A032 ignition woes kgraeser Military MEP and Aircraft Gen-Sets 24 11-12-2018 06:17:38 PM
Fichtel and Sachs Ignition Information and Parts TomLatham Antique Gas Engine Discussion 1 04-11-2016 04:33:35 AM
Wisconsin TRA12D ignition woes s100 Wisconsin Engines 7 02-01-2015 09:16:04 AM
Briggs 23D Ignition Woes gootsch Small Air Cooled Gasoline Engines 5 09-22-2014 01:28:00 PM
Onan MCCK ignition woes, mag or points? wbmiller3 Onan Generators 7 11-19-2012 11:30:11 AM
