Sally Saw
this thread has 17 replies and has been viewed 2829 times
Old 11-20-2016, 10:21:34 PM
Raydar Raydar is offline
Default Re: Sally Saw
Old 11-20-2016, 10:28:05 PM
Here are a few pictures from the Owners Manual. It is missing the cover but the other 36 pages are in good shape.
Center Fold
Front page
Some useful info
The Following User Says Thank You to Raydar For This Post:
Old 12-12-2016, 12:09:32 AM
So the good news is that we got the motor back together. Unfortunately now we don't have any spark. We had it before the tear down but now it's gone. My buddy thinks it's the condenser. Any suggestions?
Old 12-12-2016, 09:00:21 AM
mschreiber mschreiber is offline
that stand swings down to help support weight when cutting? i got 1 and didn't know this. good luck.
Old 12-12-2016, 10:52:45 AM
T Hickok MN T Hickok MN is offline
I think you best have lunch before you go to the woods with Sally!!
Old 12-12-2016, 11:32:42 PM
s100 s100 is offline
If you had spark before but have none now, my first thing to check would be the points. If they are not burned clean them with a piece of paper soaked with electronic contact cleaner. If they are burned file don't sand or replace. Make sure the gap is right. Also inspect for grounded wires, broken wires or a spark plug wire with a break or crack in the insulation. Use an ohm meter to make sure things that are supposed to be grounded are, and things that aren't supposed to be, aren't. Check the coil for continuity, as well. It's easy to check the condenser, but I count it unlikely as the source of your problem. Good luck!
Old 04-07-2018, 04:48:20 PM
hawidmer hawidmer is offline
Hi Raydar: I also have a sally saw, complete and running ,all original, including stand. also looking for owners manual
Old 01-12-2019, 05:42:44 PM
Hi I also have a sally saw, all original, and runs good. would like to get a copy of the owners manual that you have access to. is that possible ?
Sally Saw Tom Winland Chain Saw Collectors 2 01-02-2014 04:35:32 PM
Sally saw and a Mall saw antlers Chain Saw Collectors 6 06-16-2011 09:02:13 PM
I found a Sally Saw - any one have information? economypowerkingfan Farm + Industrial Antiques and Collectibles 13 09-13-2009 09:07:58 PM
I found a Sally Saw - any one have information? economypowerkingfan Chain Saw Collectors 4 03-27-2009 11:02:44 PM
Sally Saw, Clinton Engine? Mike Antique Engine Archives 0 06-08-2001 03:59:23 PM
