Stihl FS-81 brush cutter
this thread has 5 replies and has been viewed 925 times
Old 09-01-2017, 08:02:15 AM
BernieTech BernieTech is offline
Default Stihl FS-81 brush cutter
Hope this is the right place to post...
Just dug out my weedwacker circa mid 70's. Last used abt 12 years ago. Fuel was run dry at that time. I rinsed out the tank and added fresh 2 cyc mix. I do have spark. When I pulled the plug it is wet w fuel. It will not fire.
Before I tried to start it I pulled the plug and it was dry and in good shape. I did give it a squirt of fogging oil. The wacker is in almost mint condition, was rarely used.
A local Stihl dealer will do a diagnostic for short $ and has a carb cleaning machine. I would like to try getting it going first. To me, it is most likely a carb issue. Has any one used the cheap "ebay" carbs from China?
After this I have two Stihl chain saws of the same age to tackle...
Thanks,
Bernie
Old 09-01-2017, 10:11:24 AM
gdstew gdstew is offline
Default Re: Stihl FS-81 brush cutter
If you have spark and gas, it should run. Check the exhaust outlet on the muffler for being plugged up. Also, remove the air filter when trying to start.
Old 09-01-2017, 10:13:22 AM
check muffler for critters.check muffler screen if equipped with one.
Old 09-01-2017, 02:05:50 PM
me bad...this am I rechecked the sp plug gap, right on the $$$. pulled cord a few times w plug reinstalled, no gas on plug. I guess what I saw on plug was the fogging oil. put a few drops of 2 cyc gas and oil mix in combustion chamber, reinstalled plug. gave a pull and it fired..
My guess, not getting fuel. now the ?, install a "china" carb or take it to the shop for carb service.
What would the "experts" do?
Thanks for the replies so far.
Bernie
Old 09-02-2017, 03:13:16 AM
Motormowers's Avatar
I would just go on Ebay and get a new carb for $35.00 with free shipping rather than take it to a shop. It doesnt pay to take the time to tear the old ones down and clean and rebuild. Doesnt matter if its a Stihl boxed carb or aftermarket. They're all made in China now just priced different for the name you pay for.
Remove the all rotten apples out of your basket of life and toss them in the trash where they belong.
Old 09-02-2017, 10:42:39 AM
Thanks, good advice, as always from the Smokstak gang...
Bernie
Brush cutter advice needed bartlett0815 Garden Tractors / Mowers / Scooters 15 06-10-2016 06:36:09 PM
Wisconsin thd grass/brush cutter medicaid Garden Tractors / Mowers / Scooters 5 02-18-2015 10:27:06 PM
Gravely Brush Cutter Tim B Garden Tractors / Mowers / Scooters 13 01-22-2012 02:55:45 PM
Stihl TS 350 pigsticka911 Chain Saw Collectors 1 02-24-2011 09:10:05 PM
brush cutter keith york Antique Engine Archives 2 04-22-2003 08:18:45 AM
