Flint and Walling engine
this thread has 12 replies and has been viewed 5274 times
Old 06-26-2005, 08:38:48 PM
Chuck Woycke Chuck Woycke is offline
Default Flint and Walling engine
sat.at auction i bought a flint&walling 1 1/2hp,hopper cooled sparkplug /buzz coil,lunk carb.made in kendallville ind.it has a M casted on the lower base.does anyone have any information on this engine? it does not look anything like the ones in the byb pp176.thanke-chuck
Old 06-26-2005, 10:06:51 PM
Dan Grace Dan Grace is offline
Default Re: flint and walling engine
the last flint&walling I saw was a midelton aka woodpecker can you post a pic hope this helps dan
Old 06-27-2005, 05:59:44 AM
Doug Kimball's Avatar
Doug Kimball Doug Kimball is online now
Chuck,
Here's photo of one from an auction.
Name:	08 (Small).jpg
Old 06-27-2005, 07:06:13 AM
Tom Winland's Avatar
Tom Winland Tom Winland is offline
Photo Re: flint and walling engine
Here is a picture of my original 2HP Flint & Walling
Flint & Walling
Tom Winland
Ohio
Old 06-27-2005, 10:23:48 PM
Mark Congden's Avatar
Mark Congden Mark Congden is offline
I have a Flint and Walling water pump (from Kendallville) that I run with a 1 1/2 hp Leader iron works engine...sure would like to run it with an F&W engine!! ....Mark Congden
Old 06-28-2005, 07:58:22 PM
thanks to everyone that answered or sent me a e-mail.from what i found out flint and walling never made a gas engine.the early ones were made by almo the latter ones by woodpecker.what i have been told is if your engine is missing a tag.standing behind the flywheels on the left side on the block by the base if there is a M casted into the block like mine it's a flint&walling if it has a W it's a woodpecker. has anyone else heard this.if you have eather engine please let me know if yours has such a casting mark,thanks chuck
Old 06-30-2005, 07:32:24 PM
Andrew Albrecht's Avatar
Andrew Albrecht Andrew Albrecht is offline
Chuck: I have a Flint Wallings Pump Jack that would go good with your engine. Let me know if your interested. Andy
I Get My Corn From A Jar
Old 08-14-2006, 10:50:10 PM
Earle Franklin Earle Franklin is offline
Hi Chuck,
Another "Newbee" to Smokstak. I work at Flint & Walling and also have a
1 1/2 h.p. serial #1857-k. There is still alot of speculation if F&W made thier own engines. If you notice your tag it says "Reg. U.S. Pat. Off." This suggests that F&W made engines that look like the "Woodpecker". Just recently seen an original decal that says the same thing. Also, the early engines (1901) were Charter Engines of Chicago,Il. Alamo listed "Hoosier"
(A F&W trade name) as an approved agent. I have seen one Hoosier/Flint & Walling 1 1/2 hp that is an Alamo. The Woodpecker style engine were first listed in catalog 100 dated 1915.
What is your serial Number? I am thinking about starting a listing of numbers and pictures. To answer another thread, if you have no tag the serial number is stamped into the end of the crankshaft. Standing behind the engine it will be on the left end of the crankshaft.
Earle
Old 09-07-2008, 10:14:18 PM
Jim Sampson Jim Sampson is offline
I use a Flint & Walling water pump at my cabin in Michigan and the connecting rod broke and damaged the bottom of the housing. Do you possibly want to sell yours? If not do you know where I can purchase one?
Please advise.
Thanks,
Jim Sampson
Old 09-07-2008, 10:18:09 PM
I have a Flint & Walling water pump at my cabin in Michigan and the connecting rod just broke and damaged the housing.
Do you want to sell yours?
If not can you tell me where I can possibly find one?
Please advise.
Thanks,
Jim Sampson
Old 08-03-2014, 10:20:04 AM
BSerfass BSerfass is offline
Hi Earle,
I know this is an old thread but I am still trying to figure out the manufacturer of the Flint & Walling I have. I believe this is the early style that would have been made by Alamo..
Serial #11645 1 1/2 HP
Can you verify?
Thanks in advance Brian Serfass
Name:	Flint Walling Smokstak 003.jpg
The Following User Says Thank You to BSerfass For This Post:
Old 08-03-2014, 03:02:19 PM
M&WJOE M&WJOE is offline
Default Re: Flint and Walling engine
Brian, My engine is like yours. I think Stover had something to do with it. I will get a picture. Not in this computer.
Old 08-13-2017, 09:49:17 PM
Earle Earle is offline
Just sent message to another old thread. I now own this engine. Just got it in March 2017 from Tony Sage along with a 2 hp #11618 that was once owned by Bill Miller. There is only 27 numbers between these pumps. From numbers on the castings I am sure they are Alamo.
The Following User Says Thank You to Earle For This Post:
Flint And Walling Hoosier Engine Target Driller Hit & Miss Gas Engine Discussion 2 08-04-2016 07:02:26 AM
Anyone seen a Flint and Walling like this? JKWidener Farm Antiques and Collectibles 1 08-12-2009 05:39:51 PM
flint and walling Ihorse Antique Engine Archives 3 12-13-2004 01:08:21 PM
Flint & Walling Bill Antique Engine Archives 5 02-19-2003 09:48:53 PM
Flint Walling Engine?? Andrew Antique Engine Archives 4 08-01-2002 12:20:16 AM
