Go Back   SmokStak > SmokStak® General Discussion > Computer, Camera and ISP Problems
Computer, Camera and ISP Problems Solutions for accessing and using the SmokStak® boards. Posting pictures, preventing viruses and solving internet service provider problems.
Rechargeable Batteries
this thread has 8 replies and has been viewed 2039 times
Old 08-02-2015, 05:02:57 PM
JonH JonH is offline
Default Rechargeable Batteries
Does anyone have any recommendations for rechargeable lithium aa/aaa batteries? I've got some relatively new NiMH's, but they have no shelf life. They've got to be charged just prior to use or else they'll be dead. I'm just wanting a straight-up replacement, not looking to have to cobble something together. I have read that lithium cells put out 3.7 volts per cell and either require only half the number of cells as regular aa's with the empty slots filled in with jumpers or a voltage regulator built into the cell to reduce it to 1.5v.
Any thoughts?
Thanks,
Jon
Old 08-02-2015, 06:50:20 PM
Default Re: Rechargeable Batteries
I thought the battery of choice now days was lithium-ion.......
Fast to charge, no danger of them short cycling due to developing memory and long life to boot.
http://batteryuniversity.com/learn/a..._ideal_battery
Old 08-02-2015, 07:35:51 PM
Jon, there are no official aa/aaa lithium cells. Lithium cells are designated by a five digit number and a mAh rating. AA size equivalent is 14500. 14 is the diameter in mm and 500 is the length. A good US source for rechargeable is. www.all-battery.com/li-polymersinglecells.aspx You will find lots of options there from custom packs to pouch cells.
Doc
Update: AAA equivalent is 10440.
This line left intentionally blank.
Old 08-02-2015, 07:56:39 PM
Jeff in PA's Avatar
Jeff in PA Jeff in PA is offline
I've had extremely good luck with "eneloop" brand rechargeable batteries in both AA and AAA size.
I've purchased mine off ebay. The newest ones are light & dark blue in the AA size and light & dark green in the AAA size.
The Following User Says Thank You to Jeff in PA For This Post:
Old 08-03-2015, 11:49:50 AM
Thanks guys. The only batteries I can find that match EXACTLY what I'm looking for are made by Kentli They are expensive and unfortunately, made in China. Kinda makes me skeptical of them.
Lithium or lithium ion makes little difference to me. I'm just tired of perpetually dead NiMH batteries. I do like the slow self-discharge rate on the Eneloops. May have to give them a try before I completely give up on NiMH.
http://www.metaefficient.com/recharg...ies-exist.html
Thanks,
Jon
Old 08-05-2015, 03:10:38 AM
Holy crap! $15 a CELL?
I'd rewire for a different battery configuration.
(exanple: 2x 10440 Li cells in paralell = 3.7 v out in same space as 2x AAA series = 3v out. Same idea for AA but using 14500 cells.)
Doc
If .7 volts too much a worry, series one 1N5401 diode, dropping 0.65 V more.
Old 01-03-2016, 12:12:09 PM
engine nut engine nut is offline
Images: 45
Photo Re: Rechargeable Batteries
is this for testing and practice posting pictures.trying to post pictures, this is a test. nothing to do with batterrys or spelling
Last edited by engine nut; 01-03-2016 at 12:13:21 PM. Reason: where is the post button for pics
Old 02-08-2016, 11:29:18 PM
len k len k is offline
I had a camera that used 2 AA alkaline cells, but with the display on it drained the bats dead flat in only 2-3 minutes. It was useless that way so I took a chance and used Lithium ion cells (4.1 volt). I salvaged some Lithium ion cells from a old laptop battery. I used 2 in parallel since that was the way they came. They make 4.1 Volts VS the ~ 3.1 volts of AA cell, works fine. But the cells were too large to fit inside the camera battery slots, so I used masking tape to hold them to the camera and connected it with wire.
Now instead of dieing in 2-3 minutes it's good for several months of occasional use. I just recharge them by connecting to 4.1 VDC for few hours till charging current drops off to ~ 0. My power supply can supply ~ 1.5 amps and when cells are dead charging current can be ~ 1 amp. I by-passed all the cell saftys so suppose I should make a better charger , but I put cell inside some cement blocks on cellar floor while charging for now.
Old 02-14-2016, 08:51:27 PM
Lead Head
I'd just get some Eneloops. They even usually come pre-charged at the store, so their self-discharge is very low.
What batteries to use? Jeb Lloyd Antique Engine Archives 12 10-29-2004 03:25:51 AM
32 volt batteries Vernon Generators & Electric Motors General Discussion 5 04-05-2004 11:29:32 PM
batteries dave Antique Engine Archives 6 05-19-2001 05:01:18 AM
batteries Jerry Logan Antique Engine Archives 11 06-06-2000 12:20:01 AM
