broken off bolts
this thread has 0 replies and has been viewed 2019 times
Old 01-11-2004, 11:45:02 PM
Patrick Marsh
Default broken off bolts
Any body ever use this? I saw it on another web site and thought it might be useful. X-TRACTALLOY Virtually eliminates problems associated with broken off bolts X-TRACTALLOY is a special application welding alloy designed to remove broken bolts, studs, drill bits, taps and other threaded fasteners. X-TRACTALLOY works on all types of steel, stainless steel, tool steel and nickel based alloys. It works in all positions, when the broken stud is flush with the surface or recessed deep in the housing. The extremely high strength of the alloy provides the needed torsional strength to remove even the toughest broken stud.
X-TRACTALLOY has a special flux coating that protects the threads during the welding process and an IGNITORTM tip that provide instant arc initiation.
It comes with complete instruction and is available in sizes for bolts ranging from 3/16" to over 3".
BFA 4.0 head bolts JNorton Onan Generators 2 05-02-2007 10:14:07 PM
Broken Bolts GRRRR broke my "easy out" too!! Chase Antique Gas Engine Discussion 21 08-30-2006 09:05:43 PM
Removing Broken Bolts Jim Gorter Antique Engine Archives 11 07-04-2003 09:49:54 PM
Need JD-E bolts Al Hettich Antique Engine Archives 0 06-10-2003 10:40:02 PM
BOLTS mark Antique Engine Archives 3 01-11-2001 02:12:52 PM
