Broken Crankshaft
this thread has 3 replies and has been viewed 1484 times
Old 03-10-2011, 06:16:09 PM
Yellersplash Yellersplash is offline
Default Broken Crankshaft
I have a 4A032-4 engine that has a broken crankshaft. Anyone have one? Is this a common problem with the -4 that used an electric starter?
Old 03-10-2011, 06:20:09 PM
Isaac-1 Isaac-1 is offline
Default Re: Broken crankshaft
You may want to check ebay, I think I saw one listed their recently.
Ike
Old 03-10-2011, 08:58:57 PM
25Eagle34 25Eagle34 is offline
Location: Auburn, CA. in the Sierra-Nevada Foothills on the way to Reno
The Ebay number is 270515425505 and buy it now for $11.19 in Fountain Hills, AZ. Just better check part numbers to sure it is the correct shaft. good luck. If the number does not show, just make a search for a military crankshaft on EBay.
The Following User Says Thank You to 25Eagle34 For This Post:
Old 03-11-2011, 10:33:43 AM
I just bought the crankshaft off ebay. Thanks for the lead. Now if i can just get this thing back together!!!
Tecumseh H60 - broken rod, gunked up crankshaft AlanCorey Small Air Cooled Gasoline Engines 10 07-02-2010 11:37:40 PM
Broken bearing cap Eric McKenna Antique Gas Engine Discussion 15 01-17-2008 11:27:19 AM
Broken Crankshaft Jamesk815 Antique Gas Engine Discussion 22 09-21-2007 10:34:57 PM
Broken Piston chase Antique Engine Archives 1 12-23-2001 02:12:45 PM
Broken pot-metal..... Alex Antique Engine Archives 1 12-25-1999 01:06:14 AM
