Heider Cone Replacement
this thread has 22 replies and has been viewed 4706 times
Old 01-29-2011, 03:32:41 PM
FArmstrong FArmstrong is offline
Default Heider Cone Replacement
Began getting access to the cone pulley on the Heider. Not sure how much of the pulley needs to come off the shaft.
Fred
ID:	99082   Click image for larger version
ID:	99083   Click image for larger version
The Following 3 Users Say Thank You to FArmstrong For This Post:
Old 01-29-2011, 03:39:23 PM
G Willikers G Willikers is online now
Default Re: Heider cone replacement
Fred,
I edited my post as I had said the friction was not a cone but a series of rings laminated together - but I see in your picture #3 that you already found that out! I have made up a couple of new sets by cutting rings out of sheet masonite - that seems to stand up well. Good luck.
G.
The Following User Says Thank You to G Willikers For This Post:
Old 01-29-2011, 07:45:51 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Fred,
We need to do the same thing with our Heider as well, please keep the pictures coming! Are the sections full rings? Or are they in thirds or quarters?
Old 01-30-2011, 01:16:09 PM
Here's the old friction that was on the Beaver tractor. It had some meat left to it but was sort of glazed and wouldn't grip that well.
Still some of the original old green paint on it in spots though! Motor assembly slides ahead out of rear crankshaft bearing housing to replace friction.
G.
ID:	99161   Click image for larger version
The Following 6 Users Say Thank You to G Willikers For This Post:
Old 01-30-2011, 02:32:44 PM
Paul Searl's Avatar
Paul Searl Paul Searl is offline
Default Re: Heider Cone Replacement
we ordered our replacement disk through paperpulleys.com, not as cost effective as making your own from masonite, but maybe a little less hassle, although we still had to have it milled a little to fit.
you can unhook the linkage and use a bar to slide the engine farther forward to get the extra room. we also had to unbolt the angle iron underneath of it for it to drop out.
Keep the pictures coming, I wish we had taken pictures of the process.
The Following User Says Thank You to Paul Searl For This Post:
Old 01-30-2011, 04:12:36 PM
More pictures of the tractor. First one shows come-along pulling engine forward.
Fred
ID:	99208   Click image for larger version
The Following 5 Users Say Thank You to FArmstrong For This Post:
Old 01-30-2011, 04:06:54 PM
FWurth:
It appears the sections are full rings which are pressed in tight right now. Not sure if I should get a screwdriver in there and start peeling them out or if there is a better way...
Fred
---------- Post added at 02:06 PM ---------- Previous post was at 02:01 PM ----------
Paul,
We used a come-along to slide the engine forward but we have not cleared the shaft from the rear housing yet. Are there bearings inside of that housing? Is there anything (lip) on the shaft that will keep the shaft from exiting the housing?
Fred
The Following User Says Thank You to FArmstrong For This Post:
Cone Head Rivets? dbyam Steam Stationary Engines, Traction Engines, Steam Boats 53 11-04-2013 10:53:20 PM
Blacksmith's cast iron cone? darrelld Blacksmithing and Metallurgy 2 12-24-2007 10:42:15 AM
Ball or Cone for Hercules? Chris Kirk Antique Engine Archives 1 09-15-2002 07:23:53 PM
1/2 inch Ball or Cone Mufflers Hal Davis Antique Engine Archives 0 09-10-2002 12:12:19 PM
Stuck governor cone Brian Antique Engine Archives 3 01-10-2002 07:25:28 AM
