Heider Cone Replacement
this thread has 22 replies and has been viewed 4700 times
Old 01-30-2011, 10:19:28 PM
Tom Cwach's Avatar
Tom Cwach Tom Cwach is offline
Default Re: Heider Cone Replacement
You may need to use a second comealong on the other side. Using just one may be causing the motor to bind up in the slides.
Old 01-30-2011, 10:41:05 PM
FArmstrong FArmstrong is offline
Thanks G and Tom,
You have provided a great deal of useful information.
Fred
The Following 2 Users Say Thank You to FArmstrong For This Post:
Old 01-31-2011, 02:44:12 AM
Ours was several segments of Masonite with pieces of modern house shingles laid underneath to makeup for wear. We got a paper pulley after sending the dimensions. It fit a little tight. There are 10 bolts holding it on.
Old 01-31-2011, 12:07:07 PM
How far should the fiber extend past the motor fly wheel?
Fred
Old 01-31-2011, 06:59:01 PM
farmstrong,
The more meat you start out with on the friction, the better. Just leave enough clearance so you have neutral!
Now I feel kind of embarassed putting my 2 pfennigs' worth in as I didn't get as fancy as what you guys are talking about. Being a poor dirt farmer, I used the masonite, cut and installed it in an afternoon and as for machining the friction - a couple of trips around the yard looked after that!
That is in keeping with the ol' testimonials where guys changed the friction out in the field, between loads whilst threshing and over a beverage or three!
G.
The Following 3 Users Say Thank You to G Willikers For This Post:
Old 01-31-2011, 08:12:25 PM
greysteam24hp greysteam24hp is offline
Email Over Quota
Images: 100
Fred,
Was this Heider originally came from Goshen, Indiana back in 1995?
Craig
Old 01-31-2011, 09:06:30 PM
Craig,
My brother and I adopted Buckley Old Engine Show's Heider this winter for some much needed attention. Not sure where it originally came from.
Fred
Old 02-20-2011, 10:47:03 PM
Default Heider Friction Drive
Pulled out the worn friction discs today. Brother is going to order replacments from paperpulley. Might also try cutting some from masonite.
ID:	100933   Click image for larger version
ID:	100934   Click image for larger version
ID:	100936   Click image for larger version
The Following 5 Users Say Thank You to FArmstrong For This Post:
Old 02-20-2011, 10:50:35 PM
Engine slid forward rather easily. Hard part will probably be putting new friction discs back on.
ID:	100938   Click image for larger version
ID:	100939   Click image for larger version
ID:	100940   Click image for larger version
The Following 9 Users Say Thank You to FArmstrong For This Post:
Old 02-23-2011, 12:30:30 AM
jjschott
Default Re: Heider Friction Drive
I worked with Oilpulled replacing the friction wheel on our 12-20C Heider. Paperpulley had made a few already and actually thought one might still be on the shelf! Other than a rather snug fit on the flywheel they made it perfectly based on our measurements. Approx 1/2" larger dia. than flywheel, and about 1/4" smaller than the distance between discs for neutral clearance-though would have to measure mine to say for sure. The crankshaft did slide nicely out of the housing by sliding the engine further forward. Before ordering mine, I entertained machining a stack of masonite discs, using a router bolted to a pivot arm to make perfectly reproducible circles.
Cone Head Rivets? dbyam Steam Stationary Engines, Traction Engines, Steam Boats 53 11-04-2013 10:53:20 PM
Blacksmith's cast iron cone? darrelld Blacksmithing and Metallurgy 2 12-24-2007 10:42:15 AM
Ball or Cone for Hercules? Chris Kirk Antique Engine Archives 1 09-15-2002 07:23:53 PM
1/2 inch Ball or Cone Mufflers Hal Davis Antique Engine Archives 0 09-10-2002 12:12:19 PM
Stuck governor cone Brian Antique Engine Archives 3 01-10-2002 07:25:28 AM
