this thread has 4753 replies and has been viewed 315109 times
Old 01-26-2018, 08:00:49 PM
Power Power is offline
Default Re: What Have You Done to Your Onan Generator Today?
Originally Posted by JoeE. View Post
20 years ago, the place I worked at caught fire and nearly burnt down.
I could tell some hair raising stories about things that went on in there, electrically!!! But, I'll restrain myself and save those for another day.
Waiting for the stories, Joe
Old 01-27-2018, 02:46:28 AM
Motorhead's Avatar
Nice idea Joe. Real nice trailer for the job! Always a good idea to C.Y.A. in case of an emergency. If you run diesel in any of your vehicles or not, I have used the 55 gallon BLUE thick plastic barrels to store diesel in for several years. I would rotate the fuel into my Dodge-Cummins pickup every few years and then refill the barrels.
If I may make a statement to you..... I wouldn't make it well known where you live that you have portable generation. When things get s#i++y, all rules go out the door! Then you have to bring out the guns and ammo!
My 1939 WILLYS Pickup.
Bought in 1971
The Following 4 Users Say Thank You to Motorhead For This Post:
  #3723
Old 01-27-2018, 01:28:38 PM
Hopefully... this is the last day she will have to sit outside.. covered of course.. but still.. a local electrical company is going to come by with there bobcat and put the 1800 plus pounds of onan in the trailer today
Old 01-27-2018, 01:30:58 PM
I defiantly have that area covered..
  #3725
Old 01-27-2018, 06:50:47 PM
HBSaunders HBSaunders is offline
Cranked up the 5.0 cck contractors model and ran it for 10 minutes then hooked up 2 1500 watt ceramic heaters on it for about half hour. It was measuring 114 volts and 59 hz. When I disconnected all I checked with kill a watt and idle no load was 140 volts and high 60 hz. Oil pressure stayed 30 psi entire time.may need to replace spark plugs but ran ok. Put a wood stove in the closed in tractor bay so can keep Onans warm. Another man cave.
Old 01-27-2018, 07:25:40 PM
Did you mean "defiantly" or definitely? My advice is that the latter is preferable.
That said, if you have a generator it will be obvious immediately upon its activation. If people don't already know that you have standby power, they will figure it out quickly anyway. You just have to make sure that a clear message is sent to those who would deprive you of same.
Old 01-27-2018, 08:50:34 PM
Definitely.. damn autocorrect.. when I moved here.. there were signs up right after irma.. you loot.. we shoot..
My neighbors leave there 20 plus thousand rv trailers hitches unlocked in there drivways.. with a easy access right to them., and are not worried about them being stolen... mine is or will be pushed tounge forword up to a Palm tree with my truck beside it and trees right on the other side.. so they would have to move my truck, cut off my hitch lock, bring 2 tires all before I could ask them wtf they are doing.. or etc.. should be good..
With the help of a bobcat.. it's in the trailer and centered and mounted.. I have to get a new thermostat housing gasket tomorrow and add new coolant and new hoses.. but the hard part is done..
ID:	301513   Click image for larger version
The Following 3 Users Say Thank You to YellowLister For This Post:
  #3728
Old 01-27-2018, 09:48:54 PM
Let me know when you get that done and I'll help you find out how well it pulls.
The Following 2 Users Say Thank You to Wayne 440 For This Post:
  #3729
Old 01-28-2018, 05:21:48 PM
Finally picked up the jb and cck that were posted on the cl section..
The jb is tri fuel! He said he could not get any spark.. looks to be unmolested.. and has the sealed v.r reg and no mouse damage.. but is missing the centrifical switch cover
ID:	301583   Click image for larger version
ID:	301584   Click image for larger version
ID:	301585   Click image for larger version
  #3730
Old 01-28-2018, 05:45:30 PM
len k len k is offline
Hooked up hoses to gas pump in my 7NHM to move gas between 2 cars, so I can replace gas tank strap that's ready to snap from rust.
Took ~ 2hours to move 20 gal of gas, long hose so high backpresure for slow flow.
