this thread has 4756 replies and has been viewed 315363 times
Old 02-14-2018, 07:14:19 PM
Motorhead's Avatar
Default Re: What Have You Done to Your Onan Generator Today?
Unless the SX460 has a frequency adjustment, (I am not fully familiar with the SX460) I would suggest setting your engine RPM up a bit to 61-61.5 Hz then set up your voltage.
AGAIN...NICE INSTALL! Sure beats the heck out of the replacement costs of the OE regulator.
I have often wondered why Onan didn't duct cooling air or at least vent the top regulator house for cooling air.
My 1939 WILLYS Pickup.
Bought in 1971
Old 02-14-2018, 10:55:47 PM
len k len k is offline
Don't think there is much wattage dissipation in the reg. Between that and metal box doesn't sound like needs cooling air, I'm guessing ~ 10-15 watts max. Besides apply cooling air and you'll get all kinds of dust accumulation. Then with bit of moisture that dust becomes conductive.
Old 02-14-2018, 11:19:14 PM
JohnnyC JohnnyC is offline
There is a simple answer why Onan didn't do that. Onan did not want to disturb the mice that are/will be living directly below in the control box in the J series gensets.
JohnnyC
New Jersey
The Following 3 Users Say Thank You to JohnnyC For This Post:
  #3784
Old 02-15-2018, 10:48:54 PM
YellowLister YellowLister is online now
I installed the 1/4 inch 3x3 angle iron under the 30 kw onan dda in the 7x14 enclosed trailer
For added security.. I used a grade 8 1/2 bolt through the angle iron though the 1/4 inch boxed frame on each end. and welded them in as well.. I don't think it's 2000 pounds will be moving.. unless a truck runs it over..
Next I need to install the floor tie downs for other onans..
And im.really thinking about putting in my 3 kw onan dsl diesel on the other side of the 63 gallon fuel tank.. would still be able to fit two ccks up front and a in in the back and be under the 4880 pound payload capacity.. just under it lol.. good thing this trailer has brakes on both axles.
I did not take any pics of them welded in... because it kinda looks like poo.. but.. laying on your side with less than 6 inches of head room and welding down, or up rarely does.. at least for me
ID:	303267   Click image for larger version
ID:	303268   Click image for larger version
The Following 3 Users Say Thank You to YellowLister For This Post:
  #3785
Old 02-15-2018, 10:58:34 PM
The mig welds I see in your pics look great, but I guess they are not the welds you refer to by welding down. Do you mean upside down??? I too have problems mig welding directly upwards. Welding downwards and sideways not really an issue.
JohnnyC
New Jersey
Old 02-15-2018, 11:27:37 PM
consolenut consolenut is offline
Spent money buying a voltage regulator from flight systems. Does that count as doing something to my green machine.
Old 02-15-2018, 11:41:31 PM
JohnnyC
New Jersey
No not upside down but close.. kinda on my side.. kinda on my back..
The.welds you see were done inside the shop.. facing down.. I can usually weld ok going down if I can get the gun up higher than the bead.. but not if its below.. just does not puddle right.. maybe I need to turn the heat and speed up, or just turn the heat up.. but that would require crawling out from under it multiple times.. and I was not having it.. maybe if I get a forklift and can lift the whole rig up I can better them in the future..
Old 02-20-2018, 10:41:02 PM
Today, I setup all my gensets for a quarterly run scheduled for tomorrow. I am currently charging the batteries. All were not too bad at all considering the last time I started any of my gensets besides the JB was last November.
In the pictures below are the 2LK(not ready for running yet), 6.5NH, 7.5JB, 4.0BFA, and a 2.5AJ. It will be a fun night tomorrow running all these at the same time, but I need more heaters/load devices.
JohnnyC
New Jersey
ID:	303623   Click image for larger version
  #3789
Old 02-20-2018, 11:11:57 PM
I need to do that too.. have not ran any of mine since September..
Yours look to nice.. like they should be at a muesuen or etc..
  #3790
Old 02-21-2018, 01:11:30 PM
A bit O/T- not "to" my Onan, but "for" my Onan-
Gathering parts for a 10kW load bank/shop heater. I have a mobile home "furnace" that has (2) 5kW elements in it and a large blower. With a little re-wiring, I can make it switchable to 5/10kW for 240 volt sets and 7.4/3.7 for 208V.
