Onan MDKD 6.5 overheaded and shut down
this thread has 11 replies and has been viewed 883 times
Old 08-09-2017, 06:22:42 PM
Aussieyachty Aussieyachty is offline
Default Re: Onan MDKD 6.5 overheaded and shut down
Hi Yobo
I have an Onan 6.5 MDKD as well . Mine is my Carbineer 46. Its done 4000 hrs & runs well ,i recently replaced the orberdorfer raw water pump & most the cooling hoses. I got rid of the metal tube in the water hose & ran a heavy hose that would hold the bend without colapsing. I flushed the cooling system with Cat coolant flush. Its was very clogged up in there needed a piece of wire to unclogg the drain. My board failed & i replaced it $600 not cheap for a very simple circuit. I also replaced the rear bearing in the Alternator a rather difficult job.
I have had difficulty finding what type of Kubota engine is fitted. Cant find any numbers on it. Im wanting to adjust the valves & need the correct tollerances.
If you can show me where you found the D950 id I will look on mine.
Im in Cairns at present leaving to sail up up to TI on Friday.
I see your in Brisvegas.
Thanks I have been searching for these for ages I owe you a beer.
Old 08-09-2017, 08:41:28 PM
BigBlockChev's Avatar
BigBlockChev BigBlockChev is offline
There is a casting number on the block directly behind the raw water pump it should say 927cc which would make it a D950 motor. Cheers Dan
It's always something simple.
One test is worth a thousand guesses.
If some is good and more is better then too much is just enough
The Following 3 Users Say Thank You to BigBlockChev For This Post:
Onan MDKD Repairs Viking66 Onan Generators 41 01-08-2018 05:31:50 PM
ONAN MDKD-1R 1B Manual mainship Onan Generators 8 12-16-2017 11:42:15 AM
Onan MDKD 7.5 TLB01 Onan Generators 12 03-16-2017 05:48:23 PM
Onan 8 MDKD Straitsman Onan Generators 9 04-22-2015 03:12:20 PM
Help! Can't start Onan 8k MDKD jeffgregory Onan Generators 10 09-17-2006 09:09:26 AM
