Onan 7.5JB Centrifugal switch HELP!
this thread has 31 replies and has been viewed 1929 times
Old 10-28-2013, 11:33:19 PM
gov2mod gov2mod is offline
Default Onan 7.5JB Centrifugal switch HELP!
I've got an Onan 7.5JB 3CR/8388AA generator with battery ignition. It was made in May 1977. When starting it, as it is cranking it tries to start but stops as soon as I let go of the start switch. If, when it's trying to start, I push the points shut on the centrifugal switch it will go ahead and start and will run fine until I shut it off. I understand the points on the centrifugal switch are supposed to shut at 900 rpm but I would guess the engine would already have to be running to reach 900 rpm. Any ideas on why I have this problem? Thanks for any help.
Old 10-29-2013, 06:47:00 AM
J. McNugget's Avatar
J. McNugget J. McNugget is offline
eMail NOT Working
Default Re: Onan 7.5JB Centrifugal switch HELP!
The points are adjustable. I believe the gap is 0.025" but someone will be along to correct that number if it is incorrect. (I'm working by memory as I dash out the door...)
John
Old 10-29-2013, 07:03:19 AM
Originally Posted by J. McNugget View Post
The points are adjustable. I believe the gap is 0.025" but someone will be along to correct that number if it is incorrect. (I'm working by memory as I dash out the door...)John
Close: .020. Like the points, be sure the contacts are clean. Has the plate assembly been removed lately, or did this just start out of "the blue"?
Old 10-29-2013, 07:49:21 AM
EricWood's Avatar
EricWood EricWood is offline
Ran across this before. If you re-adjust point gap, and it works for a while but problem returns, I'd suggest you replace the soft plunger seal and the plunger that operate the point contact. I've had units where cleaning the plunger rod doesn't even help in the long run. Don't know why. But replacing them has always worked.
The Following User Says Thank You to EricWood For This Post:
Old 10-29-2013, 12:37:48 PM
This is how the generator was when I bought it. The points are adjusted to the correct .020. If I push the points closed while cranking it starts and runs fine. I just what is supposed to pull these points closed so it can start.
Old 10-29-2013, 07:27:25 PM
On the back side of the centrifugal switch plate, there is a counter weight that rotates & causes a “sleeve” to move toward the front of the engine, allowing the nylon plunger that activates the switch to move back into the housing, thus closing the points.
If the nylon plunger is damaged or as Eric mentioned, it sticks, the plunger will not follow the “sleeve” back.
It sounds like you could use a parts manual, so you can see how it is put together. An e-mail address will get you this as well as service manuals if you would like.
Old 10-29-2013, 07:54:31 PM
It could just be gummed up from sitting for several years, I'll have to look at it. I've got a manual but it shows little of this switch. Email is gov1mod@aol.com Thanks for any help.
Old 10-29-2013, 08:11:13 PM
You should have a box full.
The Following User Says Thank You to Max Thompson For This Post:
Old 10-29-2013, 09:31:01 PM
Thanks, I really appreciate it.
Old 10-30-2013, 06:34:04 PM
I removed the switch, the diaphram and plunger, all looked great. The rubber was soft and pliable and the plunger didn't look worn or broken.
Onan 7.5 jbfl centrifugal pts part #? Mikey NY Onan Generators 18 10-14-2013 07:47:06 PM
Onan 7.5 MDJE Centrifugal switch points gap FLracer Onan Generators 3 03-19-2013 08:25:55 PM
cummins onan 15JCL centrifugal switch lyonsden Multi-Cylinder Stationary Engines and Power Units 2 02-06-2013 10:45:37 PM
GE RS-IR Centrifugal Switch Problem desertoasis1 Generators & Electric Motors General Discussion 3 09-16-2009 03:14:20 PM
Centrifugal oil cleaners Robt. Antique Gas Engine Discussion 4 03-01-2007 02:48:25 AM
