Onan JB Prefab Enclosure Options
this thread has 51 replies and has been viewed 2445 times
Old 06-25-2017, 02:53:08 PM
gtj811 gtj811 is offline
Default Re: Onan JB Prefab enclosure Options
Thanks to BRae from Michigan, I was able to pick up his spare enclosure last fall. I am finally now in the process of preparing the outside pad. I have a brick house with the gas meter outside. How far from the structure and gas meter should I plan the generator enclosure pad with the JB? Is 3 feet enough space? Hate to clear the area and then be told it is too close to the gas meter or house. Anyone have advice? Better to ask now! Thanks all.
Gregg from Wisconsin.
Old 06-25-2017, 03:33:06 PM
Motorhead's Avatar
Gregg, best to find a JB installation page, usually in the JB operators manuals. Leon N might have some of the specifics. I have a factory enclosed JB and it is right next to my gas meter. Now as to venting the air flow to and out of the set, My engine cooling air discharge points away from the house. The fan housing, my set is NOT a vacuflow, is unobstructed.
The Control panel
and gauges of my
7.5JB
Old 06-25-2017, 04:27:57 PM
Thanks. I will await Leon's expert opinion as my JB is a Magniciter and not a Vacuflow either.
Old 06-25-2017, 05:19:43 PM
MBB MBB is offline
Here is the installation instructions. Cut out more then needed
File Type: pdf Pages from JB Operators Spec AA 2-77 967-0123 .pdf (620.1 KB, 38 views)
The Following 2 Users Say Thank You to MBB For This Post:
Old 06-25-2017, 05:27:12 PM
Thanks for the details! Lots of good info but nothing about the distance from the meter. A google search came up with a 3 foot clearance so I can make this work.
Old 06-25-2017, 05:55:43 PM
Sometimes you can find free sheds on cl.. or for very cheap
Old 06-25-2017, 07:10:45 PM
If this installation needs to be inspected, you might want to talk to the inspector, I have no idea what the codes call for.
Old 06-25-2017, 07:43:21 PM
Leon N. Leon N. is offline
Gregg you should get your hands on a copy of the Magneciter equipped JB Owners 'annual and Parts List, Onan document 967-320 and the Onan tech briefs on Installation Information For Onan Electric Generator Plants, T-014 & T-029. These document s were written back in the 1960's and provide valuable information that was current in that day.and age. I followed the Onan recommendations back in 1970 and my Magneciter equipped JB has been operating very reliably since 1970. Make sure you comply with local codes about locating your standby plant close to the house or the gas meter.
One big improvement or change was the advent of synthetic lubricating oil. For many years now I have been using 5W20 full synthetic all year round with no need to to make seasonal viscosity changes anymore. My JB is exposed to below zero temperatures as well as 90+ temps in the Summer. Just make sure every start runs long enough to drive out the moisture.
You have one fine machine, the likes of which wil never be reproduced again.
The Following 2 Users Say Thank You to Leon N. For This Post:
Old 06-25-2017, 08:12:47 PM
MBB MBB is offline
Sent off T-029 and T-014 to Doug to have him add to twinslan.
The Following 3 Users Say Thank You to MBB For This Post:
Old 06-27-2017, 08:10:08 PM
Ray Lynch Ray Lynch is offline
NFPA Standard 37 has good info about generator installs. It is often adopted as part of the governing code for municipalities and their AHJ. You can check your local code to see if it applies.
You can view it online at this link.
Ray
http://www.nfpa.org/codes-and-standa...ds/free-access
The Following 2 Users Say Thank You to Ray Lynch For This Post:
Tiny Prefab Gas Stations DustyBar Farm + Industrial Antiques and Collectibles 63 02-21-2017 03:15:44 PM
Onan 6.5 nh in its new portable enclosure YellowLister Onan Generators 16 02-09-2015 03:12:43 AM
Onan MAJB enclosure Jeff Klein Onan Generators 0 06-06-2013 02:03:29 AM
Onan 4.0 cck - 4rv with enclosure lp and gasoline YellowLister Onan Generators 3 04-21-2013 10:16:17 PM
Onan 12.0 DJC Enclosure (Noisy!) Steve Dawkins Onan Generators 37 03-17-2005 05:56:07 AM
