Onan 6.5 MCCK Won't Run with the Release of Start Switch
this thread has 17 replies and has been viewed 1153 times
Old 10-06-2016, 03:54:00 PM
TreSea TreSea is offline
Default Onan 6.5 MCCK Won't Run with the Release of Start Switch
Hi guys and girls.
I have an Onan 6.5 mcck spec H. I can't really read the model number. I think it is 6.5 mcck 3CPA2288H "ish". set H870 916919
It runs great, I've spent a lot of time tweaking it. Recently it won't stay running after release of the start switch. I've read the other threads but just can't figure it out. Here's what I've figured out. If I remove the rmt fuse it starts and run great, but the stop switch doesn't work. Then I put the fuse in and it shuts down. While running it generates good AC volts. There is no dc volts while running on the CRG fuse either side. Any thoughts?
Thanks in advance. Tony
Old 10-06-2016, 04:30:21 PM
Default Re: Onan 6.5 mcck wont run with the release of start switch
There is a charge resistor on the generator end that keeps the DC voltage below a certain output.. when it.shorts or etc.. this happens.. there available on ebay or onan parts might have one...you'll have to look up the part number im.the manual for your unit.. as its been a year or so and I can't remember it
Old 10-06-2016, 05:24:23 PM
Billy J Shafer's Avatar
Resistor number is 353-0092. Common for it to go out about every ten years.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
Old 10-06-2016, 06:46:39 PM
Thanks guys!! I think I found the problem with your help. I haven't opened the gen end up before. Looks like I have some work to do.
Old 10-06-2016, 06:48:31 PM
This is the one
Old 10-06-2016, 07:00:29 PM
Hey Billy, thanks again for spending your time helping us out!
Question, the parts manual lists two of them as 353-0091? 353-0092 is a 50w, 353-0091 is a 25 w. Your thoughts? Tony
Old 10-06-2016, 07:05:13 PM
I posted the wrong one. That one is 353-0091.
Old 10-06-2016, 07:38:52 PM
Awesome. Your the best!
Old 10-17-2016, 02:29:44 PM
Ok, so I've replaced both resistors 353-0091. I'm waiting on resistor 353-0068, it should be here today. But it still won't stay running after release of the start button.
On a separate problem, the electric choke. How is it powered? 12v, 110? My wires have been snipped and trying to find where to run them.
Third, I have 110v now at my crg fuse, was thinking it should be 12v?
Thanks Tony
Old 10-17-2016, 05:26:35 PM
So, I hooked up the electric choke to 12v and nothing happens. Then I hooked it up to the wire from the CRG fuse with 110 and it glows hot like it is supposed to.
I still don't know why it won't run after releasing the start switch.
Onan 4.0 BFA-1r16004c - Stops when I release START switch ErikTande Onan Generators 16 09-12-2017 11:59:09 AM
Onan 7.5JB dies after you release start switch jfikes01 Onan Generators 29 08-04-2016 05:24:01 PM
Onan 6.5- cuts off when release the start switch Eacosta71 Onan Generators 20 08-21-2015 01:48:59 PM
Onan 4k start/stop light doesnt work and stops running when release start switch JoshD Onan Generators 12 09-06-2014 07:51:40 AM
Onan KY...Release start switch and it shuts off. okcnewbie Onan Generators 48 08-30-2014 12:56:13 PM
