Onan Emerald 4000 BGE help!
this thread has 23 replies and has been viewed 1091 times
Old 06-25-2017, 01:18:15 AM
bigGURN bigGURN is offline
Images: 1
Default Onan Emerald 4000 BGE help!
Picked up this onan for $100... was told it did run when pulled from camper... now not so much. Here is the tag:
So.... it'll run as long as I hold the start button down... let go, and it dies.
It'll stay running if I jump 12v to the coil, runs and sounds great!. Dies when I cut the 12v off.
The one issue I can find is no 120v out put... brushes look fine, the slip rings test with in spec (27ohms if memory serves is what I got)...
Could this be a board issue or should I look else where? I'm not an electronics repair guy, but need to get this up amd running as we want to use it with the new camper. Thanks in advance!
Old 06-25-2017, 07:09:32 AM
Kevin K Kevin K is offline
Default Re: Onan Emerald 4000 BGE help!
Ahhhh.... the old "it ran when it was removed" story. Still, for $100 you did good. If the generator is not producing power it will not continue to run when you release the start switch. The most likely suspect is a bad voltage regulator, about $250.
Get the service manuals here: http://www.twinslan.net/~n0nas/manuals/onan/
965-0528 Service
965-0231 Parts
965-0628 Install
965-0128 Operator
Go to page 7-7 and follow the flow chart for "engine starts but stops when start switch released".
Make sure the slip rings are clean.
The Following 4 Users Say Thank You to Kevin K For This Post:
Old 06-25-2017, 09:40:16 AM
Images: 1
Thanks. Going over that list, looks like the VR is the next and only item yet to be tested. So, I'll start there this afternoon and report back.
Old 06-25-2017, 10:49:32 AM
Gunny Gunny is offline
Do he tests in the trouble shooting tree. If you determine it is the VR, I'd recommend getting a new one from Flight Systems. A better product at a better price with a better warranty and good tech support when compared to OEM.
The Following 3 Users Say Thank You to Gunny For This Post:
Old 06-25-2017, 10:52:20 AM
Images: 1
Was looking at their products last night. Figured I'll go that route. If the VR is bad, I'll order it from them. May go ahead and replace the board too. Mine has been soldred on at some point, so for an extra $140, I may just add that to the parts list. I'll test the VR this afternoon and see what I determine.
Old 06-25-2017, 11:29:04 AM
len k len k is offline
27 sounds good if you measured it thru the brushes and with AC voltage reg unplugged. Also with reg unplugged measure from slip ring to frame should be > ~ 1,000,000 ohms ( insulation test).
To test stator with AC reg unplugged apply 12 VDC across brushes, when running stator should make :
~ 40-50 VAC out the T windings
~55-60 out the Q windings
something like ~ 7 out the B windings.
Also check that control board applies ~ 9-12 VDC to pin 7 of AC reg while starting. (flashing)
OF course check brushes for sticking ,wear, breaks.
The Following 2 Users Say Thank You to len k For This Post:
Old 06-25-2017, 11:30:29 AM
Billy J Shafer's Avatar
I have used Flight Systems for over thirty years. Good people to deal with know what they are talking about. Build a better product than OEM. I have never had a problem with them. I sent in a board for repair one Monday morning. Had it back that Friday.
Old 06-25-2017, 03:58:36 PM
Images: 1
Just went through the VR test and sure enough, it failed on the last set, terminals 5-3 came back open. So that answers that! I'll go ahead and replace the board and brushes as the board has issues and the slip rings are quite dirty. I see that Flight Systems offers a quick tool for cleaning the slip rings, so I'll add one of those to the list. Thanks for all the help!
Old 06-25-2017, 04:36:30 PM
That tool they have is a brush stone. Very easy to break. Just let it ride on the ring. Doesn't take much pressure.
Old 07-06-2017, 06:54:33 PM
Images: 1
Cleaned slip rings, new brushes, a regulator and board from flight systems and away she goes!
The Following 3 Users Say Thank You to bigGURN For This Post:
Onan Emerald 4000 generator 79hdfxse Onan Generators 11 06-19-2017 09:53:06 PM
87 Onan 4000 Emerald 1 in Class C Mokx500 Onan Generators 10 04-24-2017 07:47:46 AM
Onan Emerald Plus 4000 Vanman Onan Generators 8 04-19-2017 02:29:18 PM
Onan emerald plus 4000 1993 taki44 Onan Generators 6 03-05-2013 02:12:47 PM
Onan Emerald Plus 4000 Gen Start 1992Dutchmen Onan Generators 5 12-04-2012 08:02:04 PM
