Onan 12 MDJC - 3r/2268d (1985)
this thread has 76 replies and has been viewed 2366 times
Old 08-01-2017, 08:47:57 AM
sscummins sscummins is offline
Default Onan 12 MDJC - 3r/2268d (1985)
Hi all, wanted to thank all of you here for what help you give to the new and unknown, Been reading alot (more than when I was in school) and its very helpful.
Now onto my questions, I have a 12 mdjc - 3r/2268d (1985) and it is/was a marine, I have changed the exhaust to non-marine and looks pretty good. I had the injector pump rebuilt by accurate diesel in Florida along with my injectors. All is good now. The wiring in the control box is a mess. There was a birds nest (vacant) and when I removed it all the crap ad what ever they do in the nest caused alot of corrosive mess to the wires and connectors. It seems someone else started to rewire it with new connectors but not too recent. My question is what wires connect with what wires in the terminal blocks, there are 2 blocks, top one has like 5 wires on 1 side of it (going in or coming out) and opposite side has just 1 wire in the #1 marked slot, oh the 5 wires are in the opposite side of whats marked B+, 1, 2, 3, H. Is this correct? the bottom terminal bl;ock has 8 spots for wires,6 are filled some only on 1 side of the block? is this correct? Can someone shed some light on it, I have I think the wiring scu but I have a hard time reading wiring diagrams, my weakness.
Old 08-01-2017, 09:03:35 AM
Billy J Shafer's Avatar
Default Re: 12 mdjc - 3r/2268d (1985)
The B+,1,2,3,H are the remote start and heater wires. The bottom wires are the control wires for the system. Some may not be used. Post the full model and serial number. So we can get you the correct print.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
Old 08-01-2017, 09:23:43 AM
I don't know if this will help but look at post #14 here:
https://www.smokstak.com/forum/showthread.php?t=76793
The Following User Says Thank You to nothingbutdarts For This Post:
Old 08-01-2017, 05:19:30 PM
Default Re: Onan 12 mdjc - 3r/2268d (1985)
Sorry for the lack of info, serial # is 16C859299
12MDJC-3R/2268D
Old 08-02-2017, 03:48:20 PM
Any chance you can post pictures of your box????
Old 08-02-2017, 05:09:17 PM
Old 08-02-2017, 05:10:55 PM
Its a bee's nest, well to be politically correct, it had a birds nest on top of most of the wires
Old 08-02-2017, 07:16:16 PM
More than likely mice, not "the birds and the bees". Mouse urine is very corrosive and their teeth are hard on insulation.
Old 08-03-2017, 07:43:03 AM
Kevin K Kevin K is offline
I can't find your 12MDJC-3R/2268D generator in my database, so it is difficult to give you the correct wiring diagram.
I looked through the database for similar models, and came up with two that use the same wiring diagram: 12MDJC-3R2268S, and 15MDJCB-3R2268A. Perhaps this wiring diagram is correct for your model, or at least very close.
The Following 5 Users Say Thank You to Kevin K For This Post:
Old 08-03-2017, 09:33:29 AM
I couldn't find that model,but that print should be the one.
Onan L3179-M 1985 15 KW Deisel hurdy Onan Generators 4 07-26-2012 07:54:30 PM
Onan 12MDJC-3r/2268d 120 output only? Tburk49760 Onan Generators 5 12-07-2011 10:36:21 AM
Onan 12 KW 12.O MDJC-3CR Jasonl007 Onan Generators 7 07-23-2010 12:18:35 AM
Onan 12.0 MDJC Doug101 Onan Generators 2 03-26-2008 06:25:53 PM
Onan 6.0 DJB-3CR C spec 1985 yr - Getting to run DCWatmough Onan Generators 4 10-24-2005 11:04:14 PM
