Free Onan 15.0JC-18R/13704AB and equipment
this thread has 22 replies and has been viewed 1174 times
Old 08-04-2017, 03:57:10 PM
Biser Biser is offline
Default Free Onan 15.0JC-18R/13704AB and equipment
Free to a good home
This was the start of a project to give my shop three phase power. I'm too old to do the job and Con Edison wants too much to install the three phase feed. Someone take this before it gets ruined completely. It's been sitting under a tarp for a couple of years.
Three phase circuit breaker panel - Square D NQOD42L225CU 225 amps, 240 volts 42 positions
Three phase safety switch (disconnect) - Square D 200 amp, 240 volts
Onan LTD200-24/1448A Load Transfer Switch - Three phase, 200 amps, four wire, 120/208 volts, 50/60 Hz
Onan 15.0JC-18R/13704AB s/n A800475455, 12 volt battery required
(I have a battery, probably good that you can take)
5 cans of paint to match Onan colors
Spool of MTW wire to re-wire the controls
Muffler & flex pipe
Pictures at Generator
You have to take everything...
Located near Ossining, NY 10562
First one to confirm that they'll pick it all up will get it (all, no returns!!!)
---------- Post added at 03:57:10 PM ---------- Previous post was at 03:55:20 PM ----------
Forgot the wire - 25 or 50 feet of three phase feed line, aluminum. Take it if you want it.
The Following 8 Users Say Thank You to Biser For This Post:
Old 08-04-2017, 04:26:24 PM
Default Re: Free Onan 15.0JC-18R/13704AB and equipment
I do not know how many KW you need out of a generator but, you can get 12.5 KW single phase out of that generator!
Thank You for offering it up to us STAKERS!!!!! If I was anywhere close I would be on my way!
Old 08-04-2017, 04:26:59 PM
wxyoung2008 wxyoung2008 is offline
Email NOT Working
WoW I would be leaving now if I lived with in 1000 miles of you.
You will have a taker soon !!!!!
Old 08-04-2017, 05:13:14 PM
Calling johnnyC
Johnny C to the road trip line
The Following 3 Users Say Thank You to I like oldstuff For This Post:
Old 08-05-2017, 07:18:37 AM
Kevin K Kevin K is offline
Thank you for the very generous offer! I am sure there are many here who would grab it in a heartbeat if they were close enough. As for myself, time and space constraints make it impossible for me to get it. I hope you find a taker soon.
Old 08-05-2017, 08:13:10 AM
JohnnyC JohnnyC is offline
Originally Posted by I like oldstuff View Post
Calling johnnyC
As per MapQuest it is a 1 hour drive from my place in North Jersey to Ossining, NY (see attached picture below).
At this very moment I have my Grand Cherokee topped off with gas and parked next to the trailer. Today, I have nothing special planned with family and friends. It is very tempting, but I've already restored a 15.0 JC, fixed and flipped a 15 RJC that was given to me for pennies since the owner could not sell it since the demand for 3 phase only gensets is a limited market, and I'm looking for an Onan 1 phase genset with a Kubota diesel motor for my next project. I'm most likely one of the closest to Biser's location, but I just don't have a need for it.
If the transfer switch was a 1 and 3 phase switch, I'd be there since it is a 200 amp switch, but it is 3 phase
** On a positive note, is this genset tri-fuel???? Look at my second picture. Without doubt it will run propane and natural gas, but look at the main jet adjustment rod for gasoline that extends from the bottom of the float bowl and through the tin. Looks to be like the tri-fuel carb on my JB. None of my other J series vapor only carbs had that. The carb alone is worth the trip if it is tri-fuel. I'm sure Leon may want the starter. It looks like a Prestolite, not a Mitsubishi which came out later.... None the less, if the genset can be revived it should not be parted in my opinion.
Update:: I think I see electric choke wires and connectors at the carb. I would bet a coffee it is a tr-fuel set.
JohnnyC
New Jersey
ID:	287947   Click image for larger version
Old 08-05-2017, 10:08:33 AM
Go get it. You are 13 hours closer than I am.
Old 08-05-2017, 10:20:40 AM
If you started your journey here 13 hours ago, you would be jut as close as me
JohnnyC
New Jersey
Old 08-05-2017, 12:11:27 PM
Vanman Vanman is offline
I would imagine that some three phase switches could be "tricked" into working on single phase. But I have NO idea if this may be one of them!
Old 08-05-2017, 12:21:10 PM
My very limited experience on ATS's is some switches are 1 and 3 phase and to change them it could be as simple as moving a multi-wire connector from one location to another. My LT II switch can be configured from 1 to 3 phase of many different voltages in less than 15 seconds. I attached a picture below, but it is not the best example. The switch up for grabs is a 3 phase switch as per the data tag on the switch. I believe if it was compatible for single phase, it would be indicated on the data tag.
JohnnyC
New Jersey
Onan 7.5 free in ct EnginePat Onan Generators 15 10-11-2015 06:39:13 PM
*FREE*FREE*FREE* (well, I'll trade for a cup of coffee) JohnnyC Onan Generators 14 07-02-2015 09:25:33 AM
Onan 15.0JC-18R/13704AB initial setup Biser Onan Generators 22 09-10-2014 05:26:52 AM
Onan 15.0 JC-18R/13704AB not charging battery JonTCD Onan Generators 8 12-23-2013 07:14:48 AM
Onan 15.0JC-18R/13704AB Carburetor questions Biser Onan Generators 5 12-16-2011 07:31:21 PM
