Free Onan 15.0JC-18R/13704AB and equipment
this thread has 22 replies and has been viewed 1177 times
Old 08-05-2017, 01:47:43 PM
BigBlockChev's Avatar
Default Re: Free Onan 15.0JC-18R/13704AB and equipment
Pose the question to Billy , I am sure he would know. I think most 3 phase ATSs can be used on single phase simply by choosing which line is monitored, I don't believe they actually monitor all three. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
Old 08-05-2017, 02:02:19 PM
Jim Marcozzi Jim Marcozzi is offline
Single on a 3 phase switch should be as simple as looping one leg though the the unused one, just as you do with a motor starter that monitors each.
Old 08-05-2017, 02:30:31 PM
Richard L Richard L is offline
I feel your pain,you hate to give on a project, but sh-t happens and its best to realize it and moive on.
I just gave away a 12 DJC factory trailer mounted with enclosure and extended stack.that had less than 500 hrs on it.
I gave it to a friend of mine who needs a standby unit but has not had enough loose cash to pick one up. He is almost finished with sanding and painting, the unit and trailer, and will help him replace the wiring on the output panel.
It is nice to see how excited he and his wife are,
I am sure whoever gets your set will bring it to life, and you can help them along.
R
The Following 4 Users Say Thank You to Richard L For This Post:
Old 08-05-2017, 04:36:44 PM
EricWood's Avatar
EricWood EricWood is offline
Originally Posted by JohnnyC View Post
My very limited experience on ATS's is some switches are 1 and 3 phase and to change them it could be as simple as moving a multi-wire connector from one location to another. My LT II switch can be configured from 1 to 3 phase of many different voltages in less than 15 seconds. I attached a picture below, but it is not the best example. The switch up for grabs is a 3 phase switch as per the data tag on the switch. I believe if it was compatible for single phase, it would be indicated on the data tag.
JohnnyC
New Jersey
The old LT/LTD switches, the controls normally ran off of A and B phase. So long as you use A/B phase for your power through the contactors, it won't know if its switching three phase or single phase. Only caveat to that would be if it was a fully optioned switch at the time, with three voltage sensing modules mounted in it. If so, you would just jumper the third one's output contact (the outputs of the simple voltage sensors were simply wired in series.) Also, those sensors are long-obsolete, and should be replaced with a more modern, integrated voltage sensor appropriate for the power being supplied to the switch.
Old 08-05-2017, 04:54:54 PM
Dale Russell Dale Russell is online now
Richare L, How about some pictures when he get's it painted?
Old 08-05-2017, 05:41:27 PM
Billy J Shafer's Avatar
That switch can be converted to single phase. Simple wiring change. Just use A/B phase. Where the problem comes in. Being 208 you have to change out control relays and some timers if it has any. On a switch that old I don't think it would be worth. The amps wouldn't matter. That is just what the contacts are rated at.
I spent many hours changing voltage controls. Because the salesman got the order wrong. I bet Eric and Gunny have heard this one. But the salesman said it could be done.
The Following 3 Users Say Thank You to Billy J Shafer For This Post:
Old 08-05-2017, 06:53:53 PM
Gunny Gunny is offline
Yes. That switch will do any voltage, single or 3 phase.
Quit your arguing and bitching and go get it. Worry about the little details later.
The Following 3 Users Say Thank You to Gunny For This Post:
Old 08-06-2017, 10:05:58 AM
Biser Biser is offline
George asked for it shortly after my first posting - sorry for not posting yesterday.
The Following 2 Users Say Thank You to Biser For This Post:
Old 08-07-2017, 02:29:49 PM
George Wilson picked it up this morning along with all the other stuff. He should be half way home by now. My wife is extremely happy to get all of that stuff out of the basement and the driveway.
Let me make an unsolicited testimonial... The Warn PullzAll is an absolute wonder for moving heavy equipment around. Mine pulled that JC right up George's trailer ramp with no hesitation at all. You can look at it on Amazon. I have the 110 volt version.
The Following User Says Thank You to Biser For This Post:
Old 08-07-2017, 02:37:07 PM
Never seen one, thanks for posting! It looks handy.
http://www.northerntool.com/shop/too...5486_200455486
Onan 7.5 free in ct EnginePat Onan Generators 15 10-11-2015 06:39:13 PM
*FREE*FREE*FREE* (well, I'll trade for a cup of coffee) JohnnyC Onan Generators 14 07-02-2015 09:25:33 AM
Onan 15.0JC-18R/13704AB initial setup Biser Onan Generators 22 09-10-2014 05:26:52 AM
Onan 15.0 JC-18R/13704AB not charging battery JonTCD Onan Generators 8 12-23-2013 07:14:48 AM
Onan 15.0JC-18R/13704AB Carburetor questions Biser Onan Generators 5 12-16-2011 07:31:21 PM
