An Onan JB Performance Question
this thread has 424 replies and has been viewed 11315 times
Old 08-05-2017, 06:10:26 PM
Leon N. Leon N. is offline
Default An Onan JB Performance Question
I have been wondering for some time why my JB will not meet the 2 second response time until it is thoroughly warmed up? My JB has the tri-fuel carburetor but I alway burn the utility supplied 1000 BTU natural gas. From a cold start once up to speed dumping even with just a 4KW load on it all at once can take up two 4 seconds to return to a stable RPM. However, when fully warmed up by running for 10 minutes it will return to stable operation in less than 2 seconds applying the same 4 KW load in one step. All other specified parameters, voltage and frequency remain in the specified tolerances be it NL or with a FL of 32 amperes.
Has anyone else observed such behavior? Could this droop be due to the fuel and or that old Garretson regulator which I continue to use? I also note there is noticeable, hunting and occassional popping back through the carburetor until the unit warms up. Once fully warmed up, it behaves like a charm and the issue I describe here goes away.
To me it is no big deal, just curious if others have seen this and what if anything they did about it.
Old 08-05-2017, 07:50:53 PM
Handyhiker1 Handyhiker1 is online now
Default Re: A JB Performance Question
Just as a general engine acting like this, it sounds like it is a little lean on the fuel.
Old 08-05-2017, 07:56:56 PM
len k len k is offline
Common for engines. Never gave it much thought why they run rough when cold.
On gasoline engines I would have guessed gasoline needed a warm engine to help evaporate the liquid, but your nat gas fueled so that theory is out the window. Would expect the propane to flow fast enough to quickly purge any air that back diffused into demand reg.
Guess that leaves oil wanting to warm up and thin out, less drag. Could be heat expands clearances and makes less drag too.
The Following 2 Users Say Thank You to len k For This Post:
Old 08-05-2017, 08:22:40 PM
dracer dracer is offline
popping back threw the carb means it is running lean
Old 08-05-2017, 08:38:08 PM
Yes, it appears to be running lean when first started up. I can stop the popping by riching it up a bit. BUt, then once it has warmed up, it does not meet the Onan performance spec unless I lean it out a tad. So what is the likely hood it is the Garretson regulator?
Where are all the JB users tonight? Could they share their experience? I guess in order to comment one has to know what the Onan JB spec says. There has been lots of discussions in the past about performance in terms of frequency and voltage but little discussion about the Onan JB 2 second recovery requirement except to hear comments like my machine grunts a little bit but recovers. To me meeting this 2 second requirement is important WRT starting motor loads, like a central AC system which could be damaged, not to mention other connected loads.
Old 08-05-2017, 08:55:11 PM
MBB MBB is offline
Better to leave it run a little lean. Natural gas better to run lean than rich can burn valves and pistons if too rich. My JC does the same for about 2 minutes. It too runs on natural gas. I have yet to do a tuneup on it though since I bought it.
Old 08-05-2017, 10:52:35 PM
JohnnyC JohnnyC is offline
I be here.... Just so happens I was "playing" in my garage with my JB, ATS and controller. I had a 2kw load going through the ATS to the Utility. I simulated a power outage by cutting the utility breaker inside the garage panel. The ATS kicked and started a cold JB (75 degrees outside) and immediately transferred the 2 kw load to the JB after the JB started (3 seconds of cranking and within 2 seconds once the JB kicked over and up to speed). There was no issues, no bogging, no abnormalities. I am running on propane and the JB was NOT started or warmed up prior to my test. If you want, I can redo the test with a 4 kw load, but I know the results will be the same.
Below are two pictures showing the specs I was running this evening on each of the 2 legs (A and B) single phase.
JohnnyC
New Jersey
ID:	288029   Click image for larger version
Old 08-05-2017, 11:26:19 PM
Johnny does the ATS wait to see that the JB NL parameters, frequency and voltage are in spec before applying the load? Try your test running on 1000 BTU/CF instead of that hotter stuff they call propane.
I am beginning to think my problem is fuel related or could it be a sluggish governor? If so, but why is everything OK when hot? Oh well, I am the same way when I get up.
Yes, where are our JB user friends? Guess they all have retired knowing they have one fine running machine.
Old 08-05-2017, 11:37:13 PM
I think it is reasonable to assume that the Onan specification was based on the set's abilities at normal operating temperature, i.e, after it is "warmed up". IF it were my set, I would be satisfied with the stated performance.
The Following 2 Users Say Thank You to Wayne 440 For This Post:
Old 08-05-2017, 11:41:22 PM
Leon, I guess you want me to run the JB on NG.. That test will have to wait for now. I got a bazillion wires connected between the JB, ATS and the controller and at the moment will be extremely time consuming to separate the components in order to roll the JB from my garage to the house for a NG hookup. I don't have NG in my garage which sits about 160 feet from the house.
As for the question about the ATS, I don't have an answer without reviewing the manual for that particular operation. There is an optional time delay relay that is user adjustable to allow the generator to start and stabilize before transferring power, but I don't have that optional time delay relay. Everything happens so fast from the moment the utility goes down and the generator goes online with the load transferred.
JohnnyC
New Jersey
Farmall H Performance Help The motor kid pig guy Antique Farm Tractors 2 08-14-2015 12:19:40 AM
US Injector #4 Performance ChickenSoup Steam Stationary Engines, Traction Engines, Steam Boats 7 08-13-2014 10:42:03 PM
Onan J-Line Engine Performance Curves Leon N. Onan Generators 7 04-07-2010 09:42:07 PM
Battery Performance Nubian Onan Generators 12 03-04-2009 01:11:21 PM
