McCormick-Deering 6hp mixer (early)
this thread has 2 replies and has been viewed 968 times
Old 12-22-2014, 11:27:08 PM
Stevie Stevie is offline
Default McCormick-Deering 6hp mixer (early)
Hello I have an early 6hp M mixer. Has the two needle valves. You can't take this one apart to clean it out. It has a considerable amount of rust inside. What do you all think is the best way to clean up the inside thanks
Old 12-23-2014, 03:41:50 PM
flatbeltuzr flatbeltuzr is offline
Default Re: McCormick-Deering 6hp mixer (early)
I would start with electrolysis to start, then go from there.
Old 12-23-2014, 04:43:12 PM
Tom Fleming Tom Fleming is offline
There are some people out there that will disagree with me on my next statement, but I have used Muriatic acid to clean cast iron carb bodies to great results. Make sure you have all parts disassembled. Totally immerse the carb body in full strength Muriatic acid in a VERY VERY ventilated area, preferably outside. Let it soak for 4-5 mins, then rinse 3 times and soak again in a baking soda/water mixture. Rinse 3 more times in hot water and dry. If there is still rust present, repeat the process again.
Rust will be gone. Now, be warned, the cast iron will flash rust after this process, as it is now down to bare metal. Also, the carb should be fully degreased prior to this treatment.
1920 McCormick-Deering M mixer Stevie Antique Gas Engine Discussion 3 11-26-2014 09:37:58 PM
Early IHC/McCormick Deering Pop Bottle Top Rad Caps casertractor Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 06-01-2013 01:21:13 AM
Early McCormick-Deering M Mixer plug valve stuck Stevie Antique Gas Engine Discussion 4 03-26-2011 09:22:55 AM
McCormick Deering M 1 1/2 Carb Mixer SDP Antique Gas Engine Discussion 1 06-03-2010 11:19:58 PM
Type M McCormick-Deering mixer question Dave16405 Antique Gas Engine Discussion 4 10-05-2007 10:00:42 PM
