McCormick Deering M angle mounted mixer
this thread has 10 replies and has been viewed 1818 times
Old 01-05-2015, 01:02:28 PM
Tom Jamboretz's Avatar
Tom Jamboretz Tom Jamboretz is offline
Photo McCormick Deering M angle mounted mixer
To the non-believers. Here is a photo of my 1 1/2HP "M" with the mixer mounted at an angle. Un-like all others that I have seen. Does anyone know what the engine might have been used for? Does anyone have a similar engine? TJ
The Following 6 Users Say Thank You to Tom Jamboretz For This Post:
Old 01-05-2015, 01:14:33 PM
Gilbert_Bates Gilbert_Bates is offline
Default Re: McCormick Deering M angle mounted mixer
Does it have a chain sprocket instead of a pulley, as in cement mixer? It's angled in the right direction relative to the chain drive side to make it easier to get at the 'controls' inside a tight compartment/housing.
Old 01-05-2015, 06:01:55 PM
No, it does not have a sprocket. It has a combination flat belt pulley and a v-belt pulley. I thought I had read somewhere that the flat belt system was born in 1930.
Old 01-05-2015, 08:38:44 PM
flatbeltuzr flatbeltuzr is offline
Not sure what you meant by non-believer, but thanks for the picture. As a life time fan of the Type M engines its fascinating to me the changes that accord during the 20 year run they were produced.
Your description of the pulley that's on your engine could possibly mean it was equipped for milker service? In the other post, Rob Charles is correct in that your M could have had a Kerosene carb originally and switched at some point in its life. If your engine is Wico equipped and the serial number puts it after 1924 that would be a very unique engine, especially if its on the original skid, and the skid shows signs of a milker unit being attached to it at some point.
The Following User Says Thank You to flatbeltuzr For This Post:
Old 01-06-2015, 12:08:50 AM
clappo clappo is offline
Hi Gilbert sorry to disappoint you but carby is of later petrol only engine and has been fitted onto a kero engine.
The Following User Says Thank You to clappo For This Post:
Old 01-06-2015, 05:19:46 AM
Mtype Mtype is offline
i'm with you clappo. does your head have a water fitting or a threaded hole above the throttle butterfly and pointing towards the spark plug side of the engine? cam
The Following User Says Thank You to Mtype For This Post:
Old 01-06-2015, 10:01:43 AM
Card Sponsor
That's a sparkplug kero style head. IHC made very few of them. Is there another set of holes either open or plugged under the mixer?Just ruling out it had been modified after it left the factory.Rob
The Following 2 Users Say Thank You to Rob Charles For This Post:
Old 01-06-2015, 07:12:30 PM
Matthew Guy Clarke Matthew Guy Clarke is offline
Tom, Rob stated you have a later carb on a Plug style head that may have been made for Kerosene. I pictured for you a gas carb on an early kerosene head. Notice the angle. Then see the kerosene carb on the kerosene head, it sets straight where the gas carb sets at an angle. The bolt holes are drilled at different angle so to accommodate the extra pocket for starting and water burning.
If you look under the carb, there should be a fitting that would be in the head, that hooks a water line to the water drain, a high priced adapter drain is used.
I think you have a rare head, but the wrong carb.
ID:	215242   Click image for larger version
ID:	215243   Click image for larger version
ID:	215244   Click image for larger version
The Following 4 Users Say Thank You to Matthew Guy Clarke For This Post:
Old 01-06-2015, 08:17:30 PM
Here is a blurred shot of the top of kerosene head where carb mounts, your head should look like this, with the extra hole for water at the one side.
The Following User Says Thank You to Matthew Guy Clarke For This Post:
Old 01-08-2015, 12:23:57 AM
Bob Painter Bob Painter is offline
I just acquired a 3hp M with that same head. I have no carb, so if anyone out there has a Kerosene carb, please let me know. There are pictures of this engine on a post I started this morning entitled, (More 3hp M questions). Thanks, Bob... PS, Thank you Tom for this post, and my use of it!
McCormick-Deering 6hp mixer (early) Stevie Antique Gas Engine Discussion 2 12-23-2014 04:43:12 PM
1920 McCormick-Deering M mixer Stevie Antique Gas Engine Discussion 3 11-26-2014 09:37:58 PM
Early McCormick-Deering M Mixer plug valve stuck Stevie Antique Gas Engine Discussion 4 03-26-2011 09:22:55 AM
McCormick Deering M 1 1/2 Carb Mixer SDP Antique Gas Engine Discussion 1 06-03-2010 11:19:58 PM
Type M McCormick-Deering mixer question Dave16405 Antique Gas Engine Discussion 4 10-05-2007 10:00:42 PM
