Maytag Motor Question
this thread has 4 replies and has been viewed 1195 times
Old 11-02-2017, 07:50:41 PM
Grape Grape is offline
Images: 12
Default Maytag Motor Question
Do any maytag experts out there know if they ever made a DC motor for the washers? It would be fun to use my vintage 110V DC generator to run a washer at shows.
Thanks.
Phil Grape
Remember, to Belittle others is to Be Little yourself
Old 11-02-2017, 11:30:36 PM
Lawnboy Lawnboy is offline
Default Re: Maytag Motor Question
Yes Maytag sold washers with 110 DC motors. They also could be had in 220 volt DC, 32 volt DC as well as AC motors in 220 and 110 volt in 25 cycle, 30 cycle, 40 cycle , 50 cycle and 60 cycle versions. The 110 DC motor assembly was part number A-4066 that came with a K-994 pulley (3 inch with i/2 inch bore).
The Following 2 Users Say Thank You to Lawnboy For This Post:
Old 11-03-2017, 02:44:57 AM
gasenginerick gasenginerick is offline
I have a 125 volt dc generator also and bought a bodine dc electric motor for my model 31 Maytag washer off Ebay they are black and look similar to the original motors.
I've seen one on Ebay recently
Bodine Electric DC Motor, NSH-55 115VDC, 2.3A, 1/4HP, 1725RPM
The Following User Says Thank You to gasenginerick For This Post:
Old 11-05-2017, 10:00:54 PM
I think any make of motor of the proper DC voltage would be appropriate. AC motors of the early years were GE and Delco. Odd voltages, odd frequencies and DC were sourced from these two and several other manufactures. 1950's, and newer AC motors were also sourced from Westinghouse and Emerson. Maytag tried to always have two sources of parts they did not make themselves. This way if one of the companies could not deliver the part for some reason, strike or equipment problems, the other company could deliver the parts. This meant Maytag did not have to shut down due to lack of a part. Maytag did make almost every part for the washers except for the motors and lubricants. They molded most of their rubber parts also.
Old 11-07-2017, 01:31:41 PM
Exclamation Re: Maytag Motor Question
They didn't make the electric motors, but they did make engines, and good ones at that!
Maytag MULTI-MOTOR nagy73s Maytag Engine Collectibles 2 10-25-2017 01:08:10 PM
Maytag Twin Air-Motor bsatom Maytag Engine Collectibles 4 04-02-2014 05:41:39 AM
Maytag motor model? Charlie Mc Antique Gas Engine Discussion 2 02-10-2013 10:00:26 AM
Maytag motor on a bicycle Frank Timmermeier Maytag Engine Collectibles 6 01-20-2012 06:54:46 PM
Maytag motor Model and others chrisco Maytag Engine Collectibles 5 05-05-2010 12:26:33 PM
