Maytag Powering an Ice Cream Freezer
this thread has 20 replies and has been viewed 4084 times
Old 04-18-2011, 11:54:27 PM
osagebowyer osagebowyer is offline
Default Maytag Powering an Ice Cream Freezer
Will a single model 92 power two 6qt. freezers in tandem?
Old 04-19-2011, 03:10:50 PM
Exclamation Re: Maytag powering ice cream
Geared down enough, you can do anything, however I think there will not be enough HP to do the job, at a speed you need. It may run one freezer though, at a time, again it's in the gearing ratios.
Old 09-26-2017, 12:50:23 AM
Tim Venetis Tim Venetis is offline
Default Re: Maytag powering an Ice Cream Freezer
I would think you could power the freezer if you used a mantis tiller gearbox and if you wanted to run another freezer use the other output shaft of the gearbox.
Old 09-26-2017, 11:50:37 AM
Doug Oldenburg's Avatar
Doug Oldenburg Doug Oldenburg is offline
I agree with Andrew.....It MAY handle ONE, but I doubt Very seriously if it would handle Both.
"So Much Iron & So Little Money"
Old 09-26-2017, 02:24:34 PM
Vanman Vanman is offline
Mmmmm... Two stroke flavored ice cream! Yummy Yummy!
Old 09-26-2017, 03:46:45 PM
Looking at this another way, the maximum continuous power that the best athlete in excellent condition can develop is ~1/4 hp, driving a crankshaft with his legs.
Therefore, if just about anyone can drive an ice cream churn with one hand, the power required to do so must necessarily be dramatically less than 1/4 hp.
So, how much power can the Maytag engine develop? 1/2 hp? I would say that, grossly inefficient gearing notwithstanding, the little engine could drive *several* churns, assuming that the gearing results in the correct speed.
I think that it's deceptive since the churns take so much torque to turn. But only at a very slow speed.
Old 09-27-2017, 06:30:13 AM
DaveRW DaveRW is offline
Images: 3
My Maytag 92 is geared through a 10 to 1 gear box and runs one 6 qt. freezer at about 60 rpm approximately 25 minutes till the ice cream is done. Most of the time when my ice cream is done my engine will die. I am not saying my engine is top notch but to run two, I do not believe it would do it efficiently with out being really geared down.
Old 09-27-2017, 08:34:46 AM
KeithW's Avatar
KeithW KeithW is offline
I run two 6 quart makers with a 5/8 HP Briggs WMB washing machine motor with no problem. The setup uses belt clutches so they can be engaged separately.
Old 09-27-2017, 10:32:53 AM
Jamesk815 Jamesk815 is offline
Images: 17
Smile Re: Maytag Powering an Ice Cream Freezer
I don't think using a Maytag well work. Not enough torque. About 1 1/2 hp
hit miss with those nice heavy flywheels would work real good.
Old 09-27-2017, 12:49:58 PM
Rex Wellendorf Rex Wellendorf is offline
Default Re: Maytag Powering an Ice Cream Freezer
Hi, I've got a "think I can Maytag" on a 6qt, works fine. Rex.
Maytag 92 powered ice cream freezer Cespilot Maytag Engine Collectibles 2 10-30-2017 02:05:05 PM
Ice cream freezer to mount to maytag washer JTaylor Maytag Engine Collectibles 3 10-31-2013 09:23:33 AM
My Maytag Ice cream freezer raggs Maytag Engine Collectibles 5 04-16-2010 04:00:49 PM
Ice Cream Freezer Jeff Conner Small Air Cooled Gasoline Engines 5 08-16-2007 10:28:02 PM
Maytag built ice cream freezer ? Nathan Grissom Maytag Engine Collectibles 1 07-24-2007 09:37:49 AM
