Onan ccka-s/1627g generator and welder starting issue
this thread has 30 replies and has been viewed 1652 times
Old 12-12-2016, 08:25:15 AM
Tbrock94 Tbrock94 is offline
Default Onan ccka-s/1627g generator and welder starting issue
I recently purchased a lincwleder 225 with a generator and it has an onan engine. It's about 22 degrees in Ohio right now. It uses 2 35 series batteries in parallel I have one bigger then a 35 series and one 35 series battery. I know one handle you pull is the choke and the other is the fuel? Would you push in or pull out to cut the fuel on? Is there another fuel switch for it? It just has a push starter and will start up with starting fluid but then dies out shortly after.
1. What is the proper way to start this engine?
2. Is there anything I need to know, tips tricks etc?
ID:	270084   Click image for larger version
ID:	270085   Click image for larger version
Old 12-12-2016, 09:13:15 AM
Billy J Shafer's Avatar
Default Re: Onan ccka-s/1627g generator and welder starting issue
Not much on welders. But I have never seen a push/pull fuel system. Can you post a picture of it.
Old 12-12-2016, 09:33:59 AM
Billy J Shafer;1342493]Not much on welders. But I have never seen a push/pull fuel system. Can you post a picture of it.
There is one that is the choke and is labeled choke(off to the left I believe) and there is also another on that is red in this image. The one on my engine pulls outwards for the choke, and what may be the fuel goes up and down. The choke on mine is right near the carburetor off to the right, and in this picture(it has a red handle) moves up and down.
ID:	270087   Click image for larger version
Old 12-12-2016, 09:36:23 AM
If you look at the first picture with the red handle that is how it is in mine, it doesnt go to the carburetor. It will fire up with starting fluid, and will die out shortly after. Is there a fuel switch somewhere.
Old 12-12-2016, 09:54:22 AM
The one that goes up and down. Is the manual prime lever. Use it to pump up the system. Then push it back down. Pump may be out. Remove the fuel line from pump to carb. Work the lever. You should get gas out of the pump.
Old 12-12-2016, 10:12:55 AM
Okay thank you so much, is there a actual fuel switch somewhere on the unit?
Old 12-12-2016, 10:21:21 AM
Not from Onan. Most just had a valve at the fuel tank. Off/On valve.
Old 12-12-2016, 10:31:10 AM
Okay I will have to see if I can locate it, I just got it in a trade.
Old 12-12-2016, 10:37:20 AM
I would remove the glass fuel bowl assembly There should be a small screen in the top. They do get clogged at times. Good idea to just take the whole thing apart and clean. Be careful with the glass easy to break.
Old 12-12-2016, 10:49:20 AM
Awesome, thanks for the advice and if you have anymore ideas I'd like to hear them
lincoln dc welder with a kablewey onan ccka engine. replacement ideas? Oddballmotorsports Welding Shop 6 09-14-2016 09:38:17 AM
onan cck welder/generator starter issue YellowLister Onan Generators 4 05-25-2013 07:57:07 AM
Onan CCKA-MS/2677G Welder/Generator merle t Onan Generators 0 08-11-2011 05:32:45 PM
Please Help Onan Generator starting issue. petergrimshaw Onan Generators 11 09-18-2010 09:26:00 AM
Onan CCKA on Miller Welder wtxonan Welding Shop 3 10-17-2008 09:48:51 AM
