What trailer(s) can haul a 1911 45hp CASE steam engine? What trailer is best?
this thread has 23 replies and has been viewed 2528 times
Old 04-11-2017, 05:04:54 PM
thefrendlyghost thefrendlyghost is offline
Default Re: What trailer(s) can haul a 1911 45hp CASE steam engine? What trailer is best?
Thanks to everyone for all of the great replies. I appreciate everyone's input. For what it's worth, the steepest grade in my area is about 7%. But, there are many hills at that grade.
I never imagined that a mid 90s/late 90s dually could pull/stop that much weight. I knew they can pull a lot because I used to work for a carnival, and their duallys hauled all the game and concession wagons.
As far as the old 5 ton, how much would be involved to convert it to 12V? I'm picturing a battery, alternator, lights, and...what? I'm guessing that it already has a generator instead of a magneto, but I'm not sure. Honestly, I've never opened the hood.
I'm not sure air brakes even existed on trucks back then, (other​ than 18 wheelers) but I would prefer to upgrade the system to have air brakes, rather than restoring whatever hydraulic system it had originally.
Old 04-11-2017, 07:35:28 PM
PFT's Avatar
PFT PFT is offline
Images: 31
If you want to convert it to air brakes, find a donor truck with trailer brake plumbing (an old tractor?). I did it with an IH Loadstar using an old Loadstar school bus as a donor, had to add the trailer plumbing myself, not hard, but a lot of work. You need to change both axles unless you find a donor with the same axles, unlikely with your current truck.
PT
Old 05-24-2017, 10:09:15 PM
IronworkerFXR IronworkerFXR is offline
Images: 49
pretty sure if that had air brakes,, you would have to redo them to current specs, can springs ,auto slack adjusters ect...
BEST BET go to a few shows and see what others are using , and of course only the ones doing it right .. and you can network with others on your plans to get the flywheel off.
JC
Old 05-25-2017, 12:02:09 AM
Beth V's Avatar
Beth V Beth V is offline
Nate,
Interesting thread, I'm glad you are looking for information. Pictures of the engine and the Chevy would really make this discussion easier. I won't debate the viability of the Chevy because I don't know its condition and capabilities.
Here's my perspective as a steam engine owner, steam engine hauler, CDL holder (everything but haz & school bus,) farmer's daughter & wife, and more:
For small engines, I like Ken's set up with the Dodge & heavy trailer (skid loader). Make sure you have power to pull and above all: power to stop safely! Make sure you have DOT approved chains and have at least 6 on the engine-all 4 corners plus front & back. Keep in mind that some states may make you pull into the weigh station. Be prepared for an inspection.
This would be my partial list based on the engines we have hauled.
  • Wooden Deck--if steel, cover with belting that is attached to the trailer.
  • WINCH!!! Always use a winch when possible because you can control the load.
  • Saddle the engine. Using the winch pull the engine up on the blocks so it is about 1 inch off of the trailer, block the rear and let it settle into the blocks. This minimizes rocking. Keep in mind that the engine will settle down into the blocks and you'll need to check your chains.
  • Use at least 6 high tensile (DOT reg) chains-all 4 corners plus front & rear. If using snap or over the center binders, wire the handles.
  • Check your chains about a mile down the road and again especially if you have rough roads. You'll be surprised on how they loosen.
  • I prefer never to put the wheels up against the gooseneck or beaver tail. Some prefer it that way, but I'm not a fan.
  • I prefer to haul with water in the boiler as I was always taught it helps cushion the tubes. Other folks prefer hauling dry.
  • DOT check the trailer if it isn't yours. Use a creeper to run the underside looking for bad cross members, faulty wiring, brake lines, etc. Check the tires especially if you are hauling heavy or in heat.
  • Watch for tree limbs. They will take out a stack or a governor if you hit them just right.
  • Be prepared for gawkers. They are a hazard.
  • Make sure everything on the platform is secure from oil cans, coal, wood, tools, tool boxes, bunkers, tanks, pokers, etc. You'll be surprised what will fly.
  • Make sure the smokebox and firebox doors are securely closed.
  • Make sure the water tanks are empty and secure! DOT will stop you if you have spray (believe me...they thought I had a hot brake.) You can also crack castings.
Check out these threads in the Steam Forum:
https://www.smokstak.com/forum/showt...hlight=Hauling
Personally, I prefer our Kenworth with the folding gooseneck double drop lowboy as shown here with my 24 hp Port Huron and then my niece's 20-75 Nichols & Shepard. Both engines are overwidth as you can see by the flags.
The last is our tilt bed single drop lowboy with the 16 Reeves with water wagon and the Polaris.
Name:	Beth & Missys Nic heading out3.jpg
ID:	282821   Click image for larger version
The Following 4 Users Say Thank You to Beth V For This Post:
What trailer do I need to haul my engines? Karl T Schwab Trucks, Trailers and Hauling for Shows 5 05-30-2011 10:40:05 AM
U-Haul car trailer to haul a model T Dwight S Trucks, Trailers and Hauling for Shows 27 05-30-2008 08:34:21 PM
Trailer for steam engine Dan Dyman Steam Stationary Engines, Traction Engines, Steam Boats 18 03-18-2008 12:25:34 PM
Engine Trailer Mike Antique Engine Archives 11 01-05-2003 01:52:46 AM
