Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Honda, Yamaha, Kawasaki, Isuszu Generators
Carburetor Jetting Honda Engine (Clone Actually)
this thread has 6 replies and has been viewed 254 times
Old 07-10-2019, 12:51:10 PM
Email NOT Working
Default Carburetor Jetting Honda Engine (Clone Actually)
Against my better judgement I took on a project to repair this Honda clone generator.
It is a very close copy of a Honda so I am wondering if someone can tell me what the jetting is supposed to be.
The engine has a propane spud in the carburetor and it runs fine on propane but it will not run on gasoline without full choke.
The customer has replaced the carburetor 2x at the insistence of the company, with the same results. But he lost the original carb so I can't compare.
Everything else, fuel flow, etc. checks out and the carb looks brand new inside, because it is.
Old 07-10-2019, 04:42:14 PM
Default Re: Carburetor Jetting Honda Engine (Clone Actually)
What engine clone is it. What's the corresponding Honda engine model. What Kw is the gen.
Old 07-10-2019, 05:51:31 PM
Stock jet on a predator 212cc (~GX-200) is 0.038"
You can also get performance jets here:https://www.gopowersports.com/clone-...redator-212cc/
But, best way to proceed is to obtain a micro drill bit set and a pin drill. Find which bit just passes through jet and move up one bit at a time till engine runs as desired. Mistakes can be soldered shut and redrilled.
Doc
https://www.walmart.com/ip/25-Pcs-Pr...-Set/444121146
"i'm here tonight as living proof that not every American boy can grow up to be President." - Barry Goldwater, 1973 celebrity roast
Old 07-10-2019, 10:38:15 PM
Email NOT Working
Sorry, it is a 420cc engine.
Closest I know of is GX390 but did Honda make one bigger?
Brand of generator is Heavy Duty Power Systems and brand of engine is Jiangsu Jiangdong.
Old 07-11-2019, 12:01:56 AM
This source might help. Jet size should be stamped on it. Remove bowl, jet in middle of float. Use GOOD fitting screwdriver to remove. Easy to muck up those threads.
Doc
https://www.bmikarts.com/Main-Carbur...yABEgKOIPD_BwE
This place offers full set of jets in mm sizes for about $25 +sh.
https://www.bikeberry.com/catalogsea.../?cat=0&q=Jets
Old 07-11-2019, 01:26:24 AM
Email NOT Working
Yeah the Chinese did not stamp a number on this one. Saves money I guess. So I am not sure what is in there.
Old 07-11-2019, 07:46:59 AM
I did a quick search and came up with https://www.jackssmallengines.com/ja...9/carburetor-1
This particular model uses a #95 main jet. I suppose you could start there and see how it runs.
Honda Clone 13 hp Generator Too Much power Shawsplace56 Honda, Yamaha, Kawasaki, Isuszu Generators 12 06-13-2016 10:36:15 PM
Briggs/Honda Clone Lubrication at Incline Recomendations Keith B. Small Air Cooled Gasoline Engines 3 02-16-2016 07:02:45 PM
Honda Clone generator backfires out the carb, any idea? rbooe05 Honda, Yamaha, Kawasaki, Isuszu Generators 8 12-09-2013 11:51:42 PM
Propane kit for Honda GX 200 clone richard.bessey Honda, Yamaha, Kawasaki, Isuszu Generators 1 10-26-2013 04:10:30 PM
Honda GX200 196cc 6.5HP clone low voltage 6.24vac rusking Honda, Yamaha, Kawasaki, Isuszu Generators 13 12-25-2010 02:10:10 PM
