Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Honda, Yamaha, Kawasaki, Isuszu Generators
Honda, Yamaha, Kawasaki, Isuszu Generators Restoring, maintaining and operating Honda, Yamaha, Kawasaki, Isuszu, and clones.
free honda eb6500
this thread has 4 replies and has been viewed 912 times
Old 10-09-2016, 10:15:29 PM
EnginePat EnginePat is offline
Default free honda eb6500
So I was offered a eb6500 Honda generator from the local fix it place.
They said when it warmed up it smoked under load really bad so they did not want to repair it and gave it to the fix it shop.
So I picked it up and had to get a couple of things for it because the pull starter and air cleaner were robbed off of it before I got there to pick it up.
I started it and they said it smoked and it did so I shut it down and thought I should check the oil. When I did I unscrewed the dipstick and oil came gushing out! Not mixed with gas but oil. I figure about 2 1/2 quarts of oil. How they ever got that much in the engine, who knows? but it could explain why the vale cover bolt was loose.
I drained all of it and put 1 quart of new oil in it and after a few minutes running it stopped smoking and runs pretty good. Maybe a valve adjustment and a new plug. People should not touch things that they have no idea how they work.
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
The Following 2 Users Say Thank You to EnginePat For This Post:
Old 10-09-2016, 10:54:01 PM
Shawsplace56 Shawsplace56 is offline
Default Re: free honda eb6500
I gather up and fix generators all the time . Its a thing that works out well for me , Many dont even get checked by the dealers for various reasons they just sit there abandon after a while . Let me say that a needle valve will leak gas and it fills up the sump. Keep a eye on the gas. The original problem could have been this or that and the solution could be that simple.. Generally that full of oil you cant turn the engine over and the muffler will billow out smoke for 10 minutes after it does start Good luck maybe you hit the Jack pot
Old 10-10-2016, 12:18:17 AM
Likely caused by how tough they make it to get at the dipstick / filler port. Somebody tipped gen to add oil. But free is good.
Doc
Old 10-10-2016, 10:05:19 PM
I ran it today after I cleaned to carb some, with my 5hp 220v compressor connected to it and ran the cabinet blaster for 3 hours. Verdict no smoke. Ran without a hitch. It's a good generator.
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
Old 10-11-2016, 10:30:35 AM
Honda Jackpot ,Just keep an eye on the oil , It sounds like you hit the lottery on that one
Honda EB6500 runing but No Power n4v4jo Honda, Yamaha, Kawasaki, Isuszu Generators 13 10-21-2016 08:34:45 AM
*FREE*FREE*FREE* (well, I'll trade for a cup of coffee) JohnnyC Onan Generators 14 07-02-2015 09:25:33 AM
xfer switch with eb6500 powerking Honda, Yamaha, Kawasaki, Isuszu Generators 10 08-10-2013 02:58:38 PM
Honda EB, EV EM EL powerking Honda, Yamaha, Kawasaki, Isuszu Generators 17 05-03-2013 09:57:47 AM
HONDA STEVE BORLAK Honda, Yamaha, Kawasaki, Isuszu Generators 0 10-31-2004 10:00:45 PM
