HELP - I Need B&S 6B S O Rings
this thread has 6 replies and has been viewed 800 times
Old 05-12-2018, 10:49:40 AM
57briggs6b-s 57briggs6b-s is offline
Default HELP - I Need B&S 6B S O Rings
so, yesterday i removed the head off my 6b s and relized that the rings were falling apart. i cannot find any o rings for sale. however does anyone know if their are and that are compatible. thanks.
---------- Post added at 10:49:40 AM ---------- Previous post was at 10:48:04 AM ----------
both valve o rings/ seals to be exact
The Following User Says Thank You to 57briggs6b-s For This Post:
Old 05-12-2018, 01:54:09 PM
gdstew gdstew is offline
Default Re: HELP - I Need B&S 6B S O Rings
B & S did not use o-rings/seals on the valve stems for that engine.
Old 06-07-2018, 07:41:41 AM
Benjamin Gradler Benjamin Gradler is offline
You should put up a photo of the engine and the parts you are talking about. What you are calling o-rings may have a proper name that would be more recognizable to the more experienced engine guys here.
You may be talking about the head gasket, which for a 6S may still be available from Briggs&Stratton. The piston-rings and valves that you can see when you take the head off and most other parts would be available from parts vendors on this website or off of Ebay.
The Following User Says Thank You to Benjamin Gradler For This Post:
Old 07-22-2018, 12:31:29 AM
courts94s courts94s is offline
If youíre talking about the valve seats. They look like Oís. So I assume thatís what youíre talking about. You can get them and almost every other part for that engine. Just keep the valve seats that popped out, and YouTube how to install them. Thereís a whole technique to it. It will just be easier to watch a video, than have me type it out here. Iíve restored three B&S Model 6B-S. Parts are everywhere.
The Following User Says Thank You to courts94s For This Post:
Old 07-22-2018, 10:29:44 PM
radiodoc radiodoc is offline
I called myself looking at the 6B-S parts blowup and parts list. I didn't see any valve seats in the blowup or listed in the parts list. Were the valve seats machined into the cylinder block?
The Following User Says Thank You to radiodoc For This Post:
Old 07-23-2018, 08:31:50 AM
You can most likely use the ones from the 60000 series engine. I have to get ready for work, and donít check Smokstak that much. Send me an email to courts94s@aol.com and Iíll show you a couple parts/diagrams.
Old 07-23-2018, 09:18:45 PM
courts94s I had time today to find and drag my old B&S binder out and take a look at the repair manuals. I forgot sometimes some parts may not appear on a parts blowup. It seems the B&S 6B-S uses for the valve seats pn: 211291 superceded by pn: 691702. He probably can check with a supplier on here to get the seats if indeed that is what he needs.
Rings OldJalopy Multi-Cylinder Stationary Engines and Power Units 3 05-16-2017 10:52:47 PM
Rings for a 4 HP F&J Andrew Mackey Antique Gas Engine Discussion 4 06-03-2012 10:27:09 PM
Using Rubber O rings for piston rings Roger U Scale Model Engineering 18 09-26-2011 06:55:35 PM
Rings Jerry B Scale Model Engineering 3 09-29-2009 10:30:20 AM
I Need Rings For Whatever This Is. Elden DuRand Small Air Cooled Gasoline Engines 4 02-21-2008 11:03:44 AM
