Briggs Crank Threads
this thread has 5 replies and has been viewed 404 times
Old 06-16-2018, 10:44:32 PM
Patrick Zeller Patrick Zeller is offline
Default Briggs Crank Threads
where can i get a left hand die for cleaning theards on wmb n,wm,etc crank shaft
Old 06-16-2018, 11:32:45 PM
Arlie Levy Arlie Levy is offline
Default Re: briggs crank theards
Try Fastenal
The Following User Says Thank You to Arlie Levy For This Post:
Old 06-17-2018, 09:42:34 AM
turbo turbo is offline
Default Re: Briggs Crank Threads
Mcmaster-Carr.
The Following User Says Thank You to turbo For This Post:
Old 06-17-2018, 10:32:06 AM
what theard is it 1/2 x28???
Old 06-17-2018, 11:18:28 AM
It's used to attach a muzzle break to a gun. It's the thread used on the end of the barrel.
The Following User Says Thank You to Pat Barrett For This Post:
Old 06-17-2018, 12:06:12 PM
Mcmaster Carr for sure but dont forget amazon
The Following User Says Thank You to Ed Radtke For This Post:
Repair/Replace Threads on Briggs FH Head Stevie Mote Small Air Cooled Gasoline Engines 20 04-13-2011 09:16:01 PM
FI Briggs Left/Right Threads MaytagRepairMan Small Air Cooled Gasoline Engines 2 05-29-2010 07:33:25 AM
Tecumseh crank threads Frank Douglas Small Air Cooled Gasoline Engines 4 03-24-2008 10:28:45 AM
Briggs FI crank threads...left or right? Bruce A Small Air Cooled Gasoline Engines 2 03-13-2008 10:51:43 AM
Stripping threads in aluminum Briggs Beanscoot Small Air Cooled Gasoline Engines 27 01-12-2008 07:21:46 PM
