Forklift Not Included
this thread has 5 replies and has been viewed 2476 times
Old 02-28-2011, 11:18:04 PM
DaveTexas DaveTexas is offline
Default Forklift Not Included
I'm sure you have heard of batteries not included well this is forklift not included.
I've now done 3 engines like this. Picked up most of the wood from home depots bargin/scrap bin for 6 bucks. If you do something like this be carefull and don't stand under the engine/load. Most important take your time.
I haven't had to load any of the 3 engines yet to go to shows because they don't run but when I do I think they will have larger skids and I will use the tilt feature of the trailer and winch them up and roll them off either with pipe under the skids or build in some removable wheels.
ID:	101551   Click image for larger version
ID:	101552   Click image for larger version
The Following 7 Users Say Thank You to DaveTexas For This Post:
Old 03-01-2011, 10:06:07 AM
Wayne Grenning's Avatar
Wayne Grenning Wayne Grenning is offline
Images: 72
Default Re: Forklift Not Included
It is amazing how creative we can be when lowering and raising engines. Thanks for sharing
The Following User Says Thank You to Wayne Grenning For This Post:
Old 03-01-2011, 01:43:18 PM
vern0n vern0n is offline
Dave, as young as you are, I figured you'd just grab them and lift them by yourself.
The Following User Says Thank You to vern0n For This Post:
Old 03-01-2011, 08:42:32 PM
Jon Rozevink's Avatar
Jon Rozevink Jon Rozevink is offline
Engine Buyer
Well thats pretty cool.
The Following User Says Thank You to Jon Rozevink For This Post:
Old 03-01-2011, 09:59:53 PM
TWSlandlord's Avatar
TWSlandlord TWSlandlord is offline
That's the hardest thing to teach newbie helpers. They're always in such a hurry!
The Following User Says Thank You to TWSlandlord For This Post:
Old 03-02-2011, 12:37:22 PM
I posted pictures but no text on how it was done
First use wood to build a platform for the back wheels of the pallet jack to roll out on. Keep the front two wheels on the trailer. This should allow the engine to clear the trailer and set down on the cribbing. Make sure this cribbing is wide enough so that your pallet jack will be able to slide in between.
Then move the cribbing from under the wheel to on top of the pallet jack forks. You will only be able to lower the engine 2-4 inches at a time. Remove wood from under the engine, lower the engine back onto the cribbing, remove wood from the pallet jack forks and so on.
Kelvinator Compressor? (Pics Included) GixXxerkid18 Multi-Cylinder Stationary Engines and Power Units 5 10-21-2010 05:56:52 PM
An Onan I haven't seen here before (pics included!) Patrick Onan Generators 185 02-22-2010 06:40:40 AM
Just a little something for the older generation to remember. Pics included Sky Antique Gas Engine Discussion 9 06-07-2008 02:01:30 PM
should the EB line be included with a CASE tractor feature Kelly Barnett Antique Gas Engine Discussion 5 12-12-2006 08:06:58 AM
Please help identify model generator. Pics included. daninpa Onan Generators 5 03-13-2006 03:58:31 AM
