Oil Field Engines
Go Back   SmokStak > SmokStak® Antique Engine Community > Oil Field Engines
Oil Field Engines A gathering place for OFES members otherwise known as "Oafs". Basically, if you like "BIG OLD GREASY RUSTY OIL FIELD ENGINES, you're in the right place. Founded by Russell Farmer.
Oil Field Engines
Fairbanks ZC 118
this thread has 3 replies and has been viewed 1311 times
Old 03-29-2015, 01:26:53 PM
Bloppy Bloppy is offline
Default Fairbanks ZC 118
Hello,i just aquired a FM ZC 118 yesterday and had some questions.
Should the oil level be in the middle of the sight glass and do i fill oil at plug
next to mag unit? Should oil be a straight 30w?
Old 03-29-2015, 03:00:02 PM
Reed Engine's Avatar
Default Re: Fairbanks ZC 118
The middle is fine. I tell my customers to use the same oil in a FM they use in their car. I like multi grade detergent.
That's an old dip stick engine. Did you get it with it? They screwed in the top cover.
Old 03-29-2015, 03:26:27 PM
Thank you Reed. I did hook up to propane and it started right up. Do you know when they quit making the dip stick engine? No idea the age of this.
And no,i did not get a dip stick with it.
Old 03-29-2015, 09:11:27 PM
The top has probably been replaced as the boss that they all have is were they drilled and tapped for the dip stick to screw into. You could retrofit a dipstick to yours. Can you drill and tap the hole? I can send you pictures of the dipstick and one could be fab'd up easy andade to look OEM.
If Fairbanks really wasnt Fairbanks... Road Torpedo Antique Gas Engine Discussion 1 03-12-2012 07:31:31 AM
Info Please? Fairbanks 2hp and Fairbanks 3hp da911vid Antique Gas Engine Discussion 5 04-19-2010 07:56:52 PM
Info please? Fairbanks 2hp and Fairbanks 3hp da911vid Antique Gas Engine Discussion 4 04-06-2010 08:52:06 PM
Fairbanks D w/ Fairbanks Waterpump TAnderson Antique Engine Photos 0 05-10-2008 11:10:52 PM
Fairbanks 3hp Z"C" with #3 Fairbanks Light Plant Pix Frank Y Antique Engine Archives 0 03-30-2003 06:32:51 PM
