Oil Field Engines
Engine Starters for Large Engines
this thread has 13 replies and has been viewed 3007 times
Old 06-22-2011, 07:08:40 AM
Bill Prine Bill Prine is offline
Default Engine Starters for Large Engines
Does anyone know where you can buy an engine starter using a 12 volt starter and a friction pulley against the flywheeel? Thanks.
Bill
Old 06-22-2011, 07:43:20 AM
Arlie Levy Arlie Levy is offline
Default Re: Engine Starters for Large Engines
You will probably have to build one. My friend and I are building one from a Briggs&stratton with a gear reduction on it. I have seen these work and they are slick.
Old 06-22-2011, 08:47:52 AM
Economy Bob Economy Bob is offline
Red face Re: Engine Starters for Large Engines
Try this company !
http://www.arrowengine.com/Products/...90_Starter.php
The Following User Says Thank You to Economy Bob For This Post:
Old 06-22-2011, 10:37:56 AM
Farmer John Farmer John is offline
if i remember right these are pricey 1500 or so .but would be nice to have...john
Old 06-22-2011, 11:27:49 AM
Weezer Weezer is offline
Check with the vintage motorcycle crowd, I've seen them used to start old board track racers & drag bikes, looked like production pieces.
Jim
Old 06-22-2011, 12:49:09 PM
Keith Kinney's Avatar
Keith Kinney Keith Kinney is offline
Here is one I saw several years ago at a show that I thought was pretty neat:
www.herculesengines.com/starter
Keith
Keith Kinney
www.HerculesEngines.com
The Following 6 Users Say Thank You to Keith Kinney For This Post:
Old 06-22-2011, 01:38:22 PM
Keith i like that one i may have to build one on the next rainy day...john
Old 06-22-2011, 09:43:56 PM
That rubber looks a lot like a boat trailer roller........
Old 06-22-2011, 11:32:59 PM
I thought it was a real slick design. One thing I really liked was the ability to move from engine to engine and that it didn't have to be permanently mounted to the engine. Most of the parts can be rounded up at an auto salvage yard pretty easily.
Keith
Keith Kinney
Old 06-23-2011, 05:16:12 AM
jopeter jopeter is offline
I made one using a 12v starter motor and a small rubber tyre . A couple of mistakes so it is back to the drawing board .I like the idea of using a B&S motor with reduction gear box . My engine had 32 inch Diam flywheels and a lot of compression ,that 12v motor did not have enough guts to do the job plus the rubber tyre diam was to big . It will be ok for smaller engines .
The Following User Says Thank You to jopeter For This Post:
Large Bentall Pioneer engines Roger Gurney Antique Gas Engine Discussion 6 11-01-2008 03:22:58 AM
Large Engines cheap Pacrat Antique Gas Engine Discussion 8 09-15-2006 11:43:42 AM
First Large Engines STEVEN BOREK Oil Field Engines & Related Equipment 10 05-20-2006 04:59:23 PM
Engine starters ledhorse Antique Engine Archives 19 02-27-2004 10:28:12 PM
What's required. (Large Engines) Dave Showerman Antique Engine Archives 14 01-23-2004 11:28:25 PM
