Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Chain Saw Collectors
Chain Saw Collectors Vintage chainsaws and other air cooled gas engine saws, collecting and restoring.
Help getting my Father's Mini Mac up and Running Again
this thread has 3 replies and has been viewed 289 times
Old 09-04-2018, 12:23:46 AM
flywelder flywelder is offline
Default Help getting my Father's Mini Mac up and Running Again
I have my fathers little chain saw, I would like to get it running again. It has not run in over 35 years. It turns over when I pull the starter rope. It is a mini mac. Is it practical, and wise, to get it up and running to use at my house again? Plus, I need sources for a kit to rebuild the carb, and a link to the correct kit, and I welcome all helpful tips for rebuilding this chain saw. Thank you.
ID:	317868   Click image for larger version
The Following User Says Thank You to flywelder For This Post:
Old 09-04-2018, 09:10:32 AM
gdstew gdstew is online now
Default Re: help getting my father's mini mac up and running again
What you have is a noisy, hard to handle saw that likes to fall apart. We were always replacing the screws that fell out. McCulloch later on used bigger screws. The starters were somewhat "delicate", you must short stroke them. They are fine if a keepsake or for something to play with but if you want a dependable saw, buy a new one.
The Following User Says Thank You to gdstew For This Post:
Old 09-04-2018, 09:29:02 AM
AZBolens800 AZBolens800 is offline
I tried to fix one of those, turns out you can only get part of the carb kit
Not the best saws when new and time has not done them any good.
The Following User Says Thank You to AZBolens800 For This Post:
Old 09-04-2018, 12:16:08 PM
Thank you both for responding, your info has been a tremendous help, and guidance. I will shelf this model chainsaw as a keep sake of times with dad. Much appreciated!!
Executive Model Design, Liney Machine, Mini casting's, Mini steam John Davis Scale Model Engineering 0 01-03-2016 01:33:43 PM
Running mini hit and miss motor Chris J Scale Model Engineering 25 11-24-2012 09:08:40 PM
A proud father GaarScott Steam Stationary Engines, Traction Engines, Steam Boats 22 04-27-2007 01:40:08 PM
Economy - Father & Son roger kirschenman Antique Engine Archives 0 10-03-2004 12:05:50 AM
