Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
Will a Hydraulic Cylinder Make a Good Cylinder?
this thread has 4 replies and has been viewed 548 times
Old 06-24-2019, 07:50:26 PM
ohiomotorco ohiomotorco is offline
Default Will a Hydraulic Cylinder Make a Good Cylinder?
I am in the process of building a larger hit -n-miss engine, with a 1-1/2" bore. Can fellow hobbyists share their knowledge and experience on using a hydraulic cylinder as a sleeve? My concern is whether the cast iron piston rings will seat, after honing the cylinder.
The Following User Says Thank You to ohiomotorco For This Post:
Old 06-24-2019, 09:36:14 PM
Heller D. Davis Heller D. Davis is offline
Default Re: Will a hydraulic cylinder make a good cylinder?
I have built a couple of model engines using hydraulic cylinder material for engine sleeve. Works for me.
The Following 3 Users Say Thank You to Heller D. Davis For This Post:
Old 06-25-2019, 02:13:06 AM
JasonB JasonB is offline
Default Re: Will a Hydraulic Cylinder Make a Good Cylinder?
Hydralic cylinder should have a good enough finish not to need honing, you could also run Vitron rings which would run well on the smooth bore, last couple of engines I have made I used Vitron rather than iron rings.
Old 06-25-2019, 07:26:23 AM
mschreiber mschreiber is offline
andrews shop
build. https://www.youtube.com/watch?v=dQnJ4oGGr9A
running. https://www.youtube.com/watch?v=bi5EvcGwFzA
The Following User Says Thank You to mschreiber For This Post:
Old 07-07-2019, 09:10:29 PM
Thank you for your help - I am going to use the hydraulic cylinder in my build. Will be posting flywheel pic soon, they are 12" diameter, based on electric generating type, they weigh 23# each.
Rebuilding hydraulic cylinder piston Dwayne Oxford Machine Shop and Tool Talk 18 11-12-2016 09:48:01 PM
Pneumohydraulic Drive (Cylinder) Hydraulic Power with Air dalmatiangirl61 Machine Shop and Tool Talk 5 02-20-2016 08:25:30 AM
Hydraulic cylinder repair Tom Jamboretz Machine Shop and Tool Talk 9 01-11-2009 07:09:54 PM
BIG Hydraulic Cylinder for Shop Press Redwing Machine Shop and Tool Talk 5 01-18-2007 08:39:23 PM
