TORO Tractor - early 20's? Need parts!
this thread has 32 replies and has been viewed 2726 times
Old 08-08-2017, 08:41:28 PM
Default Re: TORO Tractor - early 20's? Need parts!
Just out of curiosity, since this design was bought and developed into the Rumely Duall, how would one of those front ends look on it?
Cool project, I look forward to seeing it progressing.
Mike
The Following User Says Thank You to Mike McKnight For This Post:
Old 08-08-2017, 10:21:56 PM
That looks very presentable with those wide wheels.the Rumely front end may be identical to the Toro, I think Rumely got the rights to copy the Toro and may not have changed anything but the name.
---------- Post added at 10:21:56 PM ---------- Previous post was at 09:43:40 PM ----------
[/COLOR]https://www.smokstak.com/forum/showthread.php?t=47728
The Following User Says Thank You to David Hoover For This Post:
Old 08-09-2017, 01:42:13 AM
Jon Nessel's Avatar
Jon Nessel Jon Nessel is offline
Kinda my thinking too
The Following User Says Thank You to Jon Nessel For This Post:
Old 08-10-2017, 12:11:46 PM
Dave Brown Dave Brown is offline
Thanks Mike, David & Jon - You're may be right about the front axle being a possibility. I'd thought of that, and I have a Rumely DoAll, but it's a tricycle front, so I don't have anything to measure. I parked the DoAll next to the Toro just for a comparison of size. I don't think you can tell a whole lot from the photos, but the DoAll is considerably larger. Some of the parts look similar and may be interchangeable, but many are not. Rumely obviously re-designed much of the Toro to suit their own needs.
If someone reading this has a standard tread DoAll, I'd appreciate it if you would measure the width!
Dave B.
ID:	288313   Click image for larger version
ID:	288314   Click image for larger version
ID:	288315   Click image for larger version
The Following 5 Users Say Thank You to Dave Brown For This Post:
Old 08-10-2017, 05:59:52 PM
Barnbikes Barnbikes is offline
Almost enough room under front end to do a single front wheel.
The Following User Says Thank You to Barnbikes For This Post:
Old 08-10-2017, 08:22:28 PM
J Ware J Ware is offline
How about the front axle from an S Case tractor. The tread widths sound about the same as an S. Gary Biewer might have one in stock. A short time ago Kent Macackin had a standard doall for sale, not sure if he sold it or not, and I believe the front axle was the original but had cut downs on front. I also believe the steering gear was correct. He is a Stak menber. Sorry Kent for misspelling your name. Jim
The Following User Says Thank You to J Ware For This Post:
Old 08-10-2017, 10:49:27 PM
Rick Trotnic Rick Trotnic is offline
Guys, I have one of these tractors I had bought our West at an auction a few years ago (Nixon sale). Someone might remember it I don't have pictures at this time. There was no front axle under it and it steers with cable. A few days after the auction in a junk pile across the road there was a front axle and two wheels that had been cut apart. I have been looking for the front wheels that I had misplaced and found them recently among the weeds. I will try adding the pictures of wheels and axle which I am sure are the right ones in the next day or so. Are there No other tractors out there that are complete with the front axle under them? I think the front axle looks very similar to a Fordson the wheels are not. Thanks, Rick
The Following User Says Thank You to Rick Trotnic For This Post:
Old 08-11-2017, 06:14:05 AM
That thing is a little scary looking.
The Following 3 Users Say Thank You to Barnbikes For This Post:
Old 08-11-2017, 03:35:26 PM
30-90 Russell 30-90 Russell is offline
Don't know if this the same tractor or not but this one was sold a few years ago at auction in Indiana.
Zach
ID:	288373   Click image for larger version
ID:	288374   Click image for larger version
The Following 4 Users Say Thank You to 30-90 Russell For This Post:
Old 08-11-2017, 05:40:00 PM
Yes, 30-90, that is a Toro! Sure wish I had some of those parts!
Dave B.
1930s Toro Tractor Nevr-Enuf-Stuf Antique Farm Tractors 6 05-11-2017 01:32:07 PM
1918 Toro Tractor smtwins Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 26 02-03-2013 06:13:34 PM
Toro Tractor with Continental F226 - Need help locating parts pgeorge33 Antique Farm Tractors 11 01-01-2012 07:28:27 PM
1918 Toro Tractor Kevin G Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 12-22-2008 10:46:43 AM
Toro Tractor Help DesertExplorer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 01-06-2006 11:56:48 PM
