Onan 10HDCAA spec C start switch and hour meter always running
this thread has 6 replies and has been viewed 1509 times
Old 06-21-2013, 06:42:51 PM
lfree6 lfree6 is offline
Default Onan 10HDCAA spec C start switch and hour meter always running
Working on a 10HDCAA spec C quiet diesel, When the unit is shut down and the remote plug is disconnected the start/stop switch is lite and the hour meter is running. I pulled the main plug on what appears to be the voltage regulator and it stoped. I'm not sure if this is just the regulator or also the control board. If anyone has any suggestions or knows if theres a service manual on line I would appreciate it.
lfree6
Old 06-21-2013, 09:09:16 PM
EricWood's Avatar
EricWood EricWood is offline
Default Re: 10HDCAA spec C start switch and hour meter always running
Those two items get their battery + power from the "Local" output, or the Switched B+ output of the controller.
Not real familiar with that particular controller, but look at the controller, and see if its possible to recognize any small relays. Switched B+ should be a relay function off of the controller, I would think. If you can actually see/get to relays, try tapping them softly with the plastic handle of a screwdriver or something similar and see if the condition goes away.
Unfortunately, many boards are build now-days, with throw away technology, even though the only thing wrong may be that a particular function isn't working, and often times due to only a bad relay on the board.
I am attaching a small photo of the section of controls that are your area of concern. PM me with an email address if you need/like a copy of the manual.
eric
The Following User Says Thank You to EricWood For This Post:
Old 06-21-2013, 09:14:03 PM
EricWood's Avatar
Oops, forgot the attachment.
Name:	HDCAA St-Stp Sw circuit.jpg
Old 06-21-2013, 09:38:56 PM
Thanks. Looks like it comes off the control board. The board is a potted board cant really see anything in it. I'm checking on a price on one, I hate to guess but without a manual I have no choice.
lfree6
Old 06-21-2013, 09:46:37 PM
Before you go to cummins for a new board, check with flight systems to see if they have one for your machine.
Old 06-21-2013, 11:05:49 PM
Kpack
Post a email and someone will send you the service manual
See of you can open it here
https://www.dropbox.com/s/mshjrpv5hj...-0526Dhdcs.pdf
Hdcaa service manual
Old 06-21-2013, 11:19:43 PM
EricWood's Avatar
Manual sent to OP
The Following 3 Users Say Thank You to EricWood For This Post:
Hour meter quartz on Onan 6.5NHD window to right of 1/10? Magnetite Onan Generators 3 01-03-2012 05:52:35 PM
Onan Engine hour meter Gary lee Onan Generators 3 01-02-2012 07:05:57 PM
Onan 6.5NHE Wont stay running when you let off of the start switch. kikid Onan Generators 7 05-20-2010 12:00:15 PM
Onan Emeral III 6.5NHEAF2600B won't stay running after you let off the start switch. kikid Onan Generators 2 05-19-2010 03:35:54 PM
Onan 6.5 NH3CR-Hour Meter? zmaro Onan Generators 11 02-18-2008 03:41:04 PM
